Question about Eagle Air Tools & Compressors
No problem just wondered what the cfm is witha 5 hp 1725 rpm motor.
  • 32 Answers
General rule of thumb is 3.75 cfm per hp.
Posted on Dec 19, 2013
2 Suggested Answers
agent91
  • 2100 Answers
SOURCE: More RPM Issues for Tools 1)
I had the same problem a while back, But I didn't bother with exact speed, what I cared more about was power and speed, and not bogging down. And I had it running smooth. Of course I have no idea what the pulley diameters were, but it sounds like you should be real close with the 2 1/2 inch at the head and 5 1/2 inch at the motor spinning 1725, should be about 900? So to get 700, bring the 5 1/2 down to 4 1/2, see if it has enough speed/power.
Posted on Feb 13, 2010
When I turn it on, nothing happened.
motor either is shot or not getting electric . if motor runs then the belt is gone
Mar 08, 2015 | Delta 14-651 - Hollow Chisel Bench...
How To Interpret Or Read Nameplate On 3 Phase Motor?
The higher the voltage the lower the amperage, so advantage is its more cost effective to run it at highe voltages since power consumption is I squared x Resistance. The resistance will be the same but the lower the current the less it cost to run it.
Jul 27, 2014 | Baldor 1/2 Hp Motor M3538 1725 Rpm 5/8"...
How to connect a motor
It should be either on the nameplate or junction box cover.
Apr 24, 2014 | AO Smith Evaporative Cooler Motor 2 hp...
I have an Ingersoll Rand Type 30 air compressor. Model #234. I was given this unit because the motor had gone bad. I would like to replace the motor and use it but I was not given the bad motor with the...
One dealer for your model compressor is Northern. They are very good at replacement parts. If you do not have 3 phase power, you could shop around for 5 to 7 hp 220 v motor making sure that the motor mount will align with your plate. Pully size depends on dia. of pulley on the pump. Most pumps turn between 550 min to 1100 rpm depending on the power available and cfm requirements. Most motors turn at 1725 rpm so for example if your compressor has a 14 in. pulley then you motor will need a 5 in. pulley to turn it about 620 rpm. The larger the pulley at the motor the higher cfm produced but more amps used. Motor speed x pulley dia. divided by compressor pulley dia. To obtain more efficiency and highest cfm you will need 3 phase. Good place to see motors and two piece pulley combnations is www.grainger.com. Good luck
Sep 25, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
How can i get more cfm out of a saylor beall 703 pump. The 705 look exactly the same to me but put out 3 times the cfm. I am guessing it is the same pump just bored out or maybe stroked with a bigger motor...
The 703 has bore sizes of 3 1/2 and 1 7/8 inch with a 3 1/2 inch stroke, the 705 has bore sizes of 4 1/2 and 2 1/8 inch and stroke of 3 1/2 inches. I am also sending you a link to the cut sheets for each pump. How they determine that a 705 is used for 3 H.P. is to turn the pump at 540 rpm and at 5 H.P. it is turning at 845 rpm. this all depends on motor rpm and motor pulley diameter to get the correct ratio of rpm and horse power at the pump.
703 cut sheet link;
http://www.saylor-beall.com/userfiles/file/Cut%20Sheets/703%20Cut%20Sheet.pdf
705 cut sheet link;
http://www.saylor-beall.com/userfiles/file/Cut%20Sheets/705%20Cut%20Sheet.pdf
Mar 03, 2010 | Cfm Air Tools & Compressors
More RPM Issues for Tools 1) Have old jointer with motor..1725rpm 5 1/2" pulley.. pulley on jointer is 2 1/2" ..what is 4" jointer blade speed ? also looking for right speed for 4" jointer.. 2)...
Feb 13, 2010 | Air Tools & Compressors
Need a ge motor 1/3 hp 1725 rpm for a toledo commercial slicer or why does motor will not start until you spin shaft?
check motors bearings for oil ports try to lube first before replacing-common motor -appliance parts-online parts-catalog(grainger)or other hvac-plumbing-heating stores
Nov 04, 2009 | Kitchen Appliances - Others
What oil is inside a 1/3 HP 1725 RPM effluent pump
You can refill it with capella oil. This is the same as the oil used in refrigerator compressors, and be acquired
from stores specializing in refrigeration and airconditioning. Send us an e-mail for further assistance.
Jun 29, 2009 | Submersible Systems Submersible Sump...
Air Tools & Compressors Logo
103 people viewed this question
Top Eagle Air Tools & Compressors Experts
John Trevino
george parkes
Bill Boyd
Are you an Eagle Air Tool and Compressor Expert? Answer questions, earn points and help others
