Question about Samsung LN-T4061F 40 in. LCD HDTV
MODEL LNT4061FX/XAA VERSION CN06 - TV TURNS ON BUT ALL OF A SUDDEN THE SOUND DOES NOT WORK? WHAT COULD IT BE?
2 Suggested Answers
SOURCE: Have Model Code LNT4061FX/XAA
Three capacitors on the motherboard are bad. They cost about 2 dollars each. If you are handy, you can take the tv apart and replace them. It took me about 30 minutes. Unplug the tv. Lay it on a large table so the stand can hang off without tilting the tv with the back of the tv facing up. take all the Phillips screws off the back cover. Take the back cover off. There is a grey cover about the size of 8x11 inches on the left middle area held on by about 6 to 8 phillips screws. Take it off. Unplug the motherboard, there are about 5 different plugs. Unscrew it and take it out. There are 3 somewhat swelled 1000mf 10v capacitors in the upper area of the motherboard. Replace them with 1000mf 16v capacitors, soldering required. Make sure you install them with the ground in the proper hole. Put it all back together and you are fixed for less than ten dollars. Samsung should be doing this for free. It really makes me mad that they can put out such an expensive product and not accept responsibility for a potential fire hazard. I will make sure anyone who wants my opinion about an electrical product knows how bad samsung is. Good luck.
Posted on Sep 04, 2010
Samsung tv model LNT4061FX/XAA has good picture, but no sound. what could it need?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Dec 31, 2017 | Samsung Televison & Video
I have a samsung LN-T4061f. It will begin flashing like a strobe light after a short time then the scren goes blank. I still have sound. I have done the turning it off using a power strip and that worked...
This set may have a separate back light inverter or it may be incorporated into the power supply. Here is the parts list: http://www.shopjimmy.com/samsung/lnt4061fx/xaa
If you note, the power supply is out of stock. That is an indication that it is a common failure item.
Mar 23, 2015 | Samsung LN-T4061F 40 in. LCD HDTV
Model LNT4061FX/XAA Intermittent snow then picture. Is there a cure?
Intermitant snow means your tv is not getting signal continuously. Please check the input signal connection and source to your tv.
Dec 26, 2013 | Samsung LN-S4041D 40 in. LCD HDTV
My my samsung LNT4061FX/XAA turn on but no pictures only sound whats wrong with it
If you shine a flashlight onto the screen, can you see a very faint picture. If yes, then your lcd panel is not lighting up. Replace the inverters or the panel.
first I would check the power supply for faulty caps, replace if neccessary.
Feb 23, 2011 | Samsung LN-T4061F 40 in. LCD HDTV
Have Model Code LNT4061FX/XAA Serial No. AHBA3CSPB286150 Version CN06. When trying to turn the TV on it clicks on and off and on and off What is the problem; what is the solution??
Sep 04, 2010 | Samsung Televison & Video
I have a Samsung LNT4061FX/XAA Serial no. AHBA3CSPA03617J. The TV will not turn on. It just continues to Click and the Red light in the front goes on and off. Is there a part available to fix this problem?
Regarding the problem with LNT406FX/XAA models not powering up - I contacted Samsung @ 1-800Samsung and they issued a repair tag and put me in touch with a repair company that came out the next day and replaced the capacitors on the power supply. Apparently Samsung got a batch of bad capacitors from a supplier and they know which TVs by the serial numbers. My TV was 28 months old and there was no charge. TV works fine now. Good for Samsung for acknowledging they had bad parts for and getting the tv fixed at no charge.
Aug 17, 2009 | Samsung Televison & Video
I have a Model LNT4061FX/XAA, Ser # AHBA3CSPB07786R, Version CN06 LCD TV. It is 18 months old and I have started to have a problem with turning the set on. When I press the on button it sounds as if it...
You Need To Do A factor Reset If You Are Getting A screen Go to Settings and look for factory reset that should help you get it back up !!remember that factory settings will lose all setting you originally had !!
We Are Here To Help!!
Aug 25, 2017 | Samsung Televison & Video
Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Dec 31, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LN-T4061F 40 in. LCD HDTV Logo
193 people viewed this question
Jerry Greenberg
Jerry Greenberg
