I have a Panasonic Stereo System. It will play for a few seconds and then stop. The code is F61. I have lost my booklet, so I'm at a loss for what this means. Can you help?
    Brigadier General:
  • 8,546 Answers
A precise make and model might yield more-specific answer.
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Mar 31, 2011
F61 cd stereo system SA-AK640
F61 is an Error Code,more specifically a Fault in the Power Amp,the Stereo will need to be sent into Panasonic for Repairs.
Jan 09, 2011 | Panasonic SC-AK640 Shelf System
I got panasonic- sa-ak240 stereo system i get F61 on the display then it shuts down to standbye.
F61 is an Error Code......it's basically indicating that something inside the stereo is malfunctioning or broken.
the stereo has gone into Protection mode.....could mean there is Direct Current on one of the output rails....most likely the Power Amplifier IC in your Stereo has gone bad....a new one should solve this problem....you'll need to send it in to Panasonic for replacement of the faulty parts.
Oct 28, 2010 | Panasonic SC-AK240 Shelf System
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
Stereo error code
There are numbers of possibilities that can make your Panasonic stereo system indicates an F61 error code. Almost 100%, the system may not be able to recover from that error code, thus, it is advisable to bring your stereo system to your nearest Panasonic repair center.
By the way, May I know the model number? ...
Mar 14, 2010 | Panasonic Audio Players & Recorders
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
Code f61
the f61 code is an audio code for panasonic first make sure all connections are correct and tight for spearkes...at the base if unit has base and with connections in back of unit and are fully in to connection terminal...make sure speakers are on and not on mute ...sometimes though you may have to re strip the wires to get into connection termianl in the back of the unit if that does not work call panasonic 1-800-211-PANA(7262) for more technical support
May 15, 2009 | Panasonic Audio Players & Recorders
Error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
Aug 23, 2008 | Panasonic SC-AK640 Shelf System
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
132 people viewed this question
 Grubhead
Grubhead
