Question about Dryers
My beko tumble dryer makes a grinding noise when the drum changes direction then it changes direction after 5 seconds then its fine untill it changes direction again then its the same groaning the it changes direction then its fine its like this till the cycle is finished
SOURCE: Beko tumble dryer not drying.
is there a reset button on a beko tumble dryer drvs 62 w pls
Posted on May 14, 2009
SOURCE: My hoover tumble dryer hnv
TheOsteopath is a pure genius - have had an increasingly noisy hnv 380 and was about to get the yellow pages out for an expensive repair (or replacement) but followed the instructions to the 't' and it works perfectly. Many many thanks. You've saved my pocket and my eardrums. JS.
Posted on Jun 28, 2009
JOE LLAMA
  • 26 Answers
SOURCE: LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Posted on Apr 04, 2008
IFIXALL
  • 868 Answers
SOURCE: ge dryer makes grinding noise when drum is turning
If youve made sure that its not a roller thats dry or a belt idler pulley that dry,than yes its the motor,and oiling that will only make it worse.
Posted on May 21, 2008
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Posted on Aug 20, 2008
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
May 22, 2015 | Beko DSV64W White Vented Tumble Dryer 6...
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
Tumble dryer drum making a noise spinning
hi take top off hold back of drum see if u can pull it up if you can feel play its more than liklely the bearing wot dryer is it
Feb 13, 2014 | Beko Dryers
Beko dryer, drum is turning and heating up fine but making a loud scrapping/rubbing noise, what could it be?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 08, 2011 | Dryers
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
Hotpoint vtd20 tumble dryer is making a horrible grinding/grating noise when the drum is rotating and seems worse in 1 direction any ideas??
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances
Jan 02, 2011 | Dryers
My maytag performa dryer is drying clothes fine and the drum is tumbling the clothes, but it is making a horrible noise. When you turn the dryer on you can hear something inside the dryer unit tumbling...
heatman101
Oct 13, 2010 | Maytag Dryers
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
Apr 23, 2008 | Dryers
Dryers Logo
1,032 people viewed this question
Top Dryers Experts
