Question about Frigidaire Kitchen Ranges
After the self cleaning cycle finished, an F9 error was displayed accompanied by continuous beeping . Pressing clear button stopped it momentarily but then dr appeared on display and the F9 error again.
I called Totem Appliances and they will come tomorrow to fix it. There's a limit to
what I can do !
Posted on Aug 06, 2008
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
I attempted to hit the self clean button but received a F9 beeping flashing error until I unplugged the range from electricity. How do I stop this F9 error?
Hello & Welcome to FixYa
Error F9 means Latch unlock lower and is displayed due to obstruction in door lock mechanism. If after cleaning the door lock mechanism the problem is still there then replacing the door lock mechanism is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Amana ARGS7650SS Gas Kitchen Range
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
My oven keeps displaying the symbol "F1" and continuing to auto-clean
Try pressing the stop/cancel button, if this does not work unplug stove and wait five minutes and then plug back in, this should clear the display
Nov 16, 2009 | Frigidaire FEF366EC 30" Freestanding...
Oven door locked.
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$%!!!%!%
Oct 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door locks and F9 fault codes
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
How do I clear error beeping (F9) on my Amana gas range
try to hold in on the oven light switch plunger that the door would hit if it was closed properly. what you probably did was to pull the door open while it was trying to lock. once you hold the plunger in, then hit the clean cycle again and then push to cancel button to get the door latch to unlock the door. it may take a minute or two but that should clear up the error code and let you use the oven again.
next time if you push the clean by mistake, just let it go and then when it says "locked" just push the cancel button. it will unlock and be ready to use.
Jan 27, 2009 | Maytag MER6772 Gemini Electric Kitchen...
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Feb 10, 2008 | Kitchen Ranges
Kitchen Ranges Logo
314 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
