Question about eMachines E181H 18 inch LCD Monitor
I have a volume square in the middle of my screen. I have a E181H TFT LCD Monitor. If I push the menu button it goes away but when I release the menu button it comes back.
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
Will my dell tft show anything on screen if no input
Normally you can push the menu button on the monitor to look at menu options. If there is no input it will normally show that on the screen initially and they go into sleep mode.
Nov 06, 2013 | Dell E173FPc 17" TFT LCD Flat Panel...
The volume menu on my hp w2207 monitor keeps popping up and the volume on that menu auto-decreases down to 0. This does not bother me because the volume still works fin, since i dont use the monitor to...
Sounds like one of the buttons on the monitor is sticking physically. Try:
  • checking the buttons for dirt that might be holding it in
  • cleaning the buttons with a soft brush
Apr 15, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
Ocd lockout
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | HP W1707 LCD Monitor
Black box in middle of screen
Push your memu button and it should disappear.If that doesn't work, contact Dell.com and they will talk you through it.
Sep 14, 2009 | Dell E173FPb 17" TFT LCD Monitor
OSD main menu pop-up will not go away
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 19, 2009 | HP Pavilion F1703 17" LCD Monitor
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
Jul 27, 2017 | HP w1907 LCD Monitor
Vga componet keeps showing up on the screen.
Assuming safely that you have a Dell E173 monitor, i would suggest the following steps to fix this...
1. Press the (+) button on your monitor to make it do an auto-adjust of the display.
2. On the on screen display (OSD) which can be evoked by using the menu button on your monitor - use the +/- key to get the factory reset option high lighted and press on the menu button to execute it.
This should take care of your problem, let me know how it goes!
Jan 12, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Black Square
Turn Off the CC Caption inside the Setup Menu.
Dec 31, 2007 | Insignia IS-LCDTV32 32 in. Television
eMachines E181H 18 inch LCD Monitor Logo
547 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
