Question about Hotpoint Washing Machines
My hotpoint washer has quit spinning all the water out of the clothes. Drum still spins but you can feel it hitting the sides of the machine as it goes around. What do I need to do to fix this?
  • 822 Answers
THE DRUM SPINNING HAS NOTHING TO DO WITH MACHINE NOT EMPTYING..........
there is a seperate pump at the back of the machine....just follow the waste hose.........it may be blocked inside a small coin is perfect to clock it.........just clear it and see if it works..........
cheers
Posted on Mar 31, 2011
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Hi, I've just done a wash on my Hotpoint WMA35 but it will not do the spin cycle. I hear the usual whirring sound as if the spin is about to start, but it doesn't. I've rearranged the load but still...
Any flashing lights or extra solid lights on the control board? By "spin cycle", do you mean the final spin cycle and drainage of water through waste pipe (basically, I want to know if the washer spins then fails, or fails to begin any rotation of the drum whatsoever). I'm having problems with my WMA35 myself, so it'd be interesting to see if this a common fault.
Feb 07, 2011 | Hotpoint WMA35 Front Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The machine doesnt spin with clothes in it
Could be a blocked filter, or worn brushes in the motor.
To check filter, remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum
Remove and clean filter inside trhe hose.
Remove hose onto pump, and check for obstruction or blockage here.
To check the carbons remove motor from washer, and the carbons are located at the oppsite end to the motor pulley.
Hope this helps.
Dec 16, 2009 | Hotpoint Washing Machines
My Hotpoint Aqualtis washing machine leaves
the drain **** in the machine is partially clogged. my best guess is at the water pump. your washer needs to be serviced. call a serviceman..
Nov 15, 2009 | Washing Machines
Loud noise when spin drying, rumbling sound, sounds like concorde taking off! Hotpoint Aquarius 1200 washer dryer WD62
Remove rear panel of washer, and remove drive belt.
Spin the drum by hand, and if it feels rough, or is noisy, then the main drum bearings have failed, quite a big job to do.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
During the spin cycle, it sounds like a helicopter. So noisy that you have to leave the room and close the laundry room door.
This is difficult to work out as there are so many different symptoms. Here are my thoughts -
Dust from carbon rushes is black. Grey dust usually comes from a loose concrete weight. Loose tub weights are rare on this model but they cause a loud knocking noise which is often worse when the washing machine is revving up to spin and dying down from a spin (suspension problems are also often worse at this stage too). It's not normally a metallic sound though.
If the noise is coming from the motor banging against the sides of the machine then it will make the machine move when it happens. The whole machine may jump or move to one side. The motor often thumps the side of the washing machine on Hotpoint washers where the motor is fitted at the top of the tub and over to the right hand side. This is a daft place to fit a motor and only Hotpoint / Credo did it. I think they've eventually stopped now though.
It is normal to be able to push the drum to the side so that the motor hits the casing. If the suspension has gone, the tub should be twisted and leaning to one side more than the other or it just could be very loose. It's difficult to check suspension if you don't know how it should feel.
If the noise is coming from the inner drum hitting the heating element or throwing an object like a £1 coin (trapped between the inner drum and the outer tub) around, then the washing machine will be stable but the noise would still be a horrible metallic knocking. This is one because I suspect.
If the carbon brush is charred (as in these Hotpoint & Credo carbon brush pictures) then it's definitely faulty and needs replacing. This could cause the machine to bang about violently on spin but it normally wouldn't.
As for the clothes being covered in black marks. (Washing (laundry) is still dirty or has marks on it (marks on clothes) ). This sounds potentially ominous as it could be that the inner drum is catching on the inside of the outer tub which is often covered in gunge. As clothes are pushed through the holes in the drum on spin, this could cause them to scrape on the inner tub and pick up greasy marks. Check for play in the drum by lifting it up and down from the front. It should only lift up a mm or so. Then turn the drum so that one of the drum paddles is at the bottom. Pull the drum toward you at the point of the drum paddle. It shouldn't have any play in it. Turn the drum round and test the other two as well. If the drum spider and shaft has a crack in it then one or more of the arms will allow excess play when you pull the drum at the paddle points.
Carbon dust from a motor could never get onto clothes.
Thank You for using Fixya.com
Aug 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint aquarius WMA40S Drum wont turn at all
the drive belt needs to be replaced. if you take it to a home depot or a lowes they will replace it at a cheap price. thank you for using fixya
Feb 23, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washer spins but not enough to extract water from clothes or tub.
could be a loss belt or a kinked hose, since you say it feels weak i would think it is not getting up to speed which would be a loss belt or drive train issue, of course it could just be to big a load or on slow spin speed setting
May 22, 2008 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
