Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
I just bought all new ink ...but it was sitting for awhile until today. It wont print. It is a MFC-440CN. It has been cleaned a few times.
  • Brother Master
  • 379 Answers
Recently, I had a similar problem which turned out to be faulty non-original ink tanks (cartridges) - they had a valve which was supposed to allow air to be drawn in as ink was drawn out. It turned out they had "gummed up" and weren't allowing air in, so once a small amount of ink had been drawn out a partial vacuum was created and stopped the flow of ink.
If fitting new, original ink tanks and running the cleaning routines a few times doesn't fix the problem, then this could be several things, some of which may mean your machine will have to be repaired by a Brother agent (probably cost you more than a new one), and/or it's time to bin it.
However, sometimes it's just because the print head, or the pipes that connect the ink tanks to the printhead, have become blocked with dried out ink.
If you search on YouTube, you will find a few videos that show how to clear such blockages - you may not find your exact model number, but many Brother machines use almost identical components to many others so the basic technique will be the same. Also search on Ebay for printer cleaning/head blockage kits - quite a few printers (not just Brother) suffer similar problems and a few businesses have sprung up on EBay that sell kits to help you sort this. They sometimes have links to a video they have produced showing how to use the kit which can give you ideas. Again, your exact model number or even make might not come up but these kits might be adaptable to your machine. Got to be worth a tenner or so before binning it ! Good luck
Posted on Apr 02, 2011
Brother MFC-440CN - print quality terrible, almost non-existent in spite of many cleaning operations.
It sounds like the printhead needs to be replaced. Brother may cover the cost of repair if you call them at 877-276-8437 and tell them the prints are "missing black ink". Very common problem that a new printhead should fix.
Oct 08, 2012 | Brother MFC-440CN InkJet Printer
I have a Brother MFC-440CN.... it's been a long time since we had ink. I've been using it as a scanner for the time, until my other printer was out of ink. Well, purchased new ink. Installed the ink. ...
The problem is the print head,if you try to clean the print head and nothing printing...you need to replace the prin head (is clogged).If a have been useful pls give me a vote
100% you need to replace the print head,i'a a technician at borther and I often encounter this problem.
Mar 16, 2011 | Brother MFC-440CN InkJet Printer
Brother MFC-440CN printer will not see new cartridge
Your print-heads, which take the ink, and spray it onto the paper, have become "clogged". Run a "print-head-cleaning-cycle" to try to unclog those jets.
Nov 26, 2010 | Brother MFC-440CN InkJet Printer
Cyan ink colour not printing-changed cartridge-no difference
The print head is likely clogged. Try running a cleaning mode a few times.
Jun 26, 2010 | Brother MultiFunction Center MFC-440CN...
Wont print
what are you trying to print in black? the best way to test out a black ink is to open word pad and type some thing random and print it and see if that works. if you have a all in one printer u might have 2 inks one color and one black in the printer
Jun 01, 2009 | Brother MultiFunction Center MFC-440CN...
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
No magenta
do you use generic ink? If yes, use an original brother ink cart! Because of the additives within the brother ink, cleaning substances will keep the ph clean.
If you still have trouble please post again here
Apr 11, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC-440CN won't print color
Did you use generic carts?
Do use only original brother ink carts!
Only these have special cleaning fluids mingled with the ink.
There are several advantages, too:
You can run a special cleaning mode (DO insert original carts at first!!!)
Press menue then start bk copy then fourtimes arrow-up.
machine should switch to maintenance mode (buttons will flash).
press 7 then 6 then 4 then start bk copy. machine will refresh ink within the tubes and the print head and run a special cleaning routine. when finished press 7 then 6 then 3 then start bk copy to run a power cleaning. leave the maintenance mode by pressing 9 then 9.
The machine should print without proböems. If there is a poor quality left, the printhead is affected by bad ink and cant be fixed anymore.
Jan 24, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
47 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
