The laptop will not turn on and the power light at the front for the battery when the power module is plugged in does not light up - the laptop should have enough powerr from the battery to work for a while
  • graeme ian hunter Mar 31, 2011
    please clarify, does this work on the battery, or is the battery now discharged?
  • 32 Answers
Is there a possibility that the battery is not being charged at all from the outlet and the problem is the inlet point of the laptop where power should be going through, sounds like a possibility, check it out.thanks
Posted on Mar 31, 2011
    Problem Solver:
  • 25 Answers
Try to turn-on the laptop with only the AC adapter plugged-in. Make sure that AC Adapter & battery is in good condition cause chances are your motherboard may have gone defective. If your laptop is still under warranty call your OEM.
  • 32,281 Answers
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Inspiron 1521 will not power up
I'd say that you have exhausted your options. You can try to isolate the power on problem by removing your your memory modules, hard disk drive and see if it at least stays powered on. Here is a link from Dell for your laptop's manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1521_Owner%27s%20Manual_en-us.pdf
Feb 09, 2013 | Dell Inspiron 1521 Notebook
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
My Gateway M-6847 will not turn on. When I press the power button the wireless light and power button light just flashes quickly. Also the battery light in front stays lit while plugged in.
Hi
silly question sorry
but have you charged the battery or plugged the power cord into plug and switched on to try to charge the battery for a couple of hrs without using the laptop
Jun 23, 2011 | Gateway M-6847 Notebook PC
Compaq Presario F572us will not stay powered up. It starts and then screen goes black and shuts down. When I press the power button again it lights up but the computer powers off again.
Here's what you can try.
1. Remove the battery and try turning the laptop just from AC adapter. Maybe the battery is bad and shorting the system.
2. Try turning it on just on battery power (with AC adapter removed). Maybe the AC adapter is bad and shorting the system.
3. Try removing memory modules one by one. Maybe your failure somehow related to memory. Test the laptop with only one memory module installed. Try either one.
If nothing helps, the laptop still turns on and off by itself, most likely this is motherboard related failure.
Jan 19, 2011 | Compaq Presario F572US Notebook PC
I purchased 512MB PC2700 333 Mhz memory module on ebay.... put it in my toshiba satellite 1905-S301 , would not work right removed module and nopw it will not power on, and when i push power button with...
remove the ram and battery try to power on. also you can power off add install ram without battery if power up .
if battery light is amber and blink speed. pls check the battery .if not battery charge pls check the battery and charge circuit
Sep 09, 2017 | Toshiba Satellite 1905-S301 Notebook
HP G60-120US 15.6" Widescreen Laptop PC Notebook: when trying to turn the computer on, the 3 lights ...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP G60-120US Laptop
Compaq nx6110 PC Laptops: When i turn it on the lights flashes then goes off...
Which light flashes? If it is the battery light then perhaps your battery is empty?
When plugged into your PSU does the power light turn on? If not your PSU may have broken or the plugs fuse may have blown.
Other potential causes could be your RAM, CPU or even your system board. Check the RAM is correctly seated, if two modules are installed try removing one.
Hope this helps, www.PuterCare.com
May 17, 2010 | HP Compaq nx6110 PC Laptop
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
Laptop wont turn on orange light flashing on front indicating power plug
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | Toshiba Satellite A135-S2276 Notebook
I have a laptop and there seems to be a light currently flashing orange along the front. Ive searched everywhere to find out whats happened but the laptop won't switch on at all. Its a toshiba Prestege...
The flashing light on the front of your laptop is a low battery warning. There probably isn't enough power in the battery to turn on the laptop. You need to plug in the ac power adaptor and let the battery charge until the battery light turns from 'orange', to 'green'.
May 02, 2008 | Computers & Internet
Open Questions:
AVAST Support Number 18OO935-6318 password recovery CONTACT AVAST Antivirus TEC-H SUPPORT CAR-E VIPRE DAIL 1800-93S-6318 AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.
Jul 17, 2018 | Contact Computers & Internet
AVAST Setup installations 18OO935-63l8 CONTACT AVAST TEC-H SUPPORT CAR-E AVAST ANTI-VIRUS tech support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS tech s support contact number.AVAST ANTI-VIRUS VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number .AVAST ANTI-VIRUS tech s support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS contact contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS -VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS tech s support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS contact contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS -VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number
Computers & Internet Logo
368 people viewed this question
David Payne
David Payne
