Question about SanDisk Sansa e250 MP3 Player
Sansa mp3 player
Will not turn on how do i reset it , what button do i press to do it thank you I unplugged my e250 from my stereo (it was working great), the speakers popped and the screen went black. Now it will not turn on -- connected to a USB port or not. It seems completely dead.
    Genius:
  • 3,422 Answers
Hold down the power button for 20 seconds to do a hard reset.
Goodluck,
please don't forget to rate or accept the solution.
Posted on Aug 05, 2008
    Genius:
  • 1,226 Answers
Remove the battery and then reinsert it again, make sure battery is good and then test.
melnavz
    Genius:
  • 2,035 Answers
IF your player is not switching on then its corrupted if its within warranty you can give it company or you need to give local service center to get it fixed ...
Good luck..
How do you reset the system.
To reset the component Hi-Fi stereo system to factory settings.
  1. On the stereo system, on DECK B , press and hold the STOP button.
  2. While holding the STOP button, press and hold the TUNER ENTER button.
  3. While holding the STOP button and TUNER ENTER button, press the POWER button.
  4. Unplug the power cord from the electrical wall outlet.
  5. Plug the power cord back into the electrical wall outlet.
  6. Turn on the stereo system.
Sep 30, 2014 | Sony STR-DA3000ES Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Hy! My mp4, SanDisk, a250 is continuous: "REFRESH DATABASE" I think he over-loaded. :[ How can reset?There is no button for it. Please urgent HELP!
To RESET the e250:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Aug 23, 2010 | SanDisk Sansa e250 MP3 Player
I have a Toshiba TP61F80, i have had the tv for little less than a year. It is a GREAT tv I love it. My tv is plugged into my home stereo so when i power that on tv turns on as well. I pushed the power...
Try unplugging the unit for 10 minutes, then plug back in and try it. If the unit just has a fault this will reset it and it should work. If it does not solve your problem I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which explains the troubleshooting process and should help you isolate the problem. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 21, 2010 | Toshiba TP61F80 61 in. Rear Projection...
My Sansa Express shown in my computer as removable drive but it doesn't respond and after unplugging it splash and go die.... Any one , Thank U
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Mar 05, 2009 | SanDisk Sansa e250 MP3 Player
E250 volume fails and dial won't work
Reset and retry are the only solutions without replacing the player completely
Jun 21, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 won't turn on
Worked for me too.
I just plugged connected my e260 via synch cord to my PC and imdiately changed my mind, unplugging it. Froze it with green connecting arrows, but no "connecting" title at the top. Upon pressing the power button, the device screen went blank as if off (but I could just barely see that it was still on).
Pulling the battery worked to reset it. It restarted when I turned it on again and is now synching.
Feb 13, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E250- Only the blue light comes on? HELP????????????
Try this: Switch your Sansa e250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the e250 LCD screen displays "Welcome to Recovery Mode" (if the LCD remains black, keep pressing long enough -- about 10 seconds -- then proceed to the next step) 5. Connect your e250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa e250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the e250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa e250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... or use this Sansa Firmware Updater link: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player (or find the most updated firmware) and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your e250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your e250 and 90-99% of the time, it would boot up successfully. I hope this helps.
Apr 20, 2007 | SanDisk Sansa e250 MP3 Player
Reset button
push the power/menu button and hold it for 15 to 20 seconds until it shuts off, wait 10 more seconds, and then turn it back on.
Dec 20, 2006 | SanDisk Sansa e250 MP3 Player
Sandisk e250 mp3 player froze up and won't turn off!
To Reboot your sansa e250 without removing batteries . Switch to hold position ( right beside headphone jack ) Press and hold menu and rec buttons at the same time untill screen resets. On my player lock up usually happens when it hits a corrupt song - try to delete and reload the culprit to minimize future lock ups. Hope this helps someone out there.
Nov 15, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
