Question about LG Dryers
I have an LG DLG3744U dryer that is 2 yrs old and does not produce heat. I tried replacing the ignitor but that didnt work. HELP!
  • LG Master
  • 2,605 Answers
Welcome to FixYa.
It could be a number of things so the problem will need to be narrowed down. The place I will start is as follows, have you checked the hi-limit thermostat ?
On the LG dryers there is a "reset" for the heating element/burner funnel on the right hand side of the funnel, however they also incorporate a no reset "hi-limit thermostat" on the left side of the funnel. Once it is tripped it must be replaced. This is only present on the gas dryers.
It is located on the left side as I mentioned, but the other is on the right side of the heater housing/burner funnel and will resemble the images shown below. It is part number 6931EL3004B ( the reset typr is part # 6931EL3003C ) and available at "searspartsdirect" or "repairclinic.com" to name a couple.
i.e. NON-RESET
i.e. RESETTABLE
With the aid of an ohm meter you can check the non-reset for continuity, the other you should be able to push the center reset button ( listen closely for a "click" ) but it too can be ohmed out for continuity to confirm or dismiss it's condition.
Hope that help`s move you forward if nothing else. If so please take a second and rate the guidance and a testimony to your inquiry you received here at FixYa, either or all is appreciated.
Let me know if you can provide any further info and I'll continue to help in any manner I can. Good luck
Regards,
Macmarkus :)
Posted on Mar 31, 2011
Verify IGNITER glows the easy method
continuity checks on igniters are seldom accurate. An amperage test is the best solution. Igniters are fairly cheap, just replace if it is suspect. They are a wear item that go bad frequently.
Aug 13, 2014 | LG DLG3744U Gas Dryers
MY DRYER IS NOT HEATING AND IT IS ONLY 2 YRS OLD. I NEED TO KNOW WHAT TO DO. I AM PRETTY SURE IT IS THE HEATING HELEMENT , BUT I REALLY HOPE NOT. I NEED TO KNOW WHAT TO DO.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 16, 2011 | Samsung DV448AEE Electric Dryer
DEGX1US my dryer is running but there is no heat it is only 6 yrs old can you help
heatman101';
Jun 26, 2011 | Fisher and Paykel DEGX1 Electric Dryer
My LG Tromm DLE2532W dryer is not producing any heat
heatman101./,'
May 15, 2011 | LG DLE2532W Electric Dryer
MAYTAG LEGACY DRYER IS 3 YRS OLD TODAY AND HAS STOPPED HEATING. BREAKERS ARE NOT TRIPPED AND PROPER VOLTAGE AND VENTING IS WORKING PROPERLY. HOW HARD IS IT TO CHANGE THE HEATING ELEMENT? THANKS FOR THE...
heatman101
Apr 23, 2011 | Dryers
Dryer was working fine. Still runs, tumbles, etc, but all of a sudden, no heat. Only 2 yrs old. Cleaned vent and lint filter. Is it likely a hi limit switch (if so, can it be reset or does it need to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 13, 2010 | Samsung DV218AEW Electric Dryer
Sears kenmore dryer 2 yrs old no heat checked gas line, lint filter and vent
the ignitor need to be replace , it is the one that turn on the gas when it get to a tempeture that is correct.
May 23, 2010 | Dryers
No heat, just cool air no matter what the setting it is on.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
May 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
LG Dryer not producing heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Dryers
Not heating during drying. everything else works
There are 3 things to turns on the heat. The ignitor, the thermal sensor, The gas valve. The ignitor has to glow first when you start. if it doesn't then it has a problem right there. After the ignitor comes on, and the thermal sensor has to produce some voltage so the gas valve can open to fire a flame then the heat will start. If the thermal sensor is bad, valve can't open then the ignitor will shut down, hence there is no heat.Taking the back panel off and try look to see the ignitor when you start so you can diagnose it correctly. Good luck
Apr 22, 2010 | LG DLG5932W Gas Dryer
Dryers Logo
203 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
