Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
I have a frigidaire affinity dryer. The dryer takes forever to dry clothes. One exmple is 3+ hours to dry towes. It is electric and I have recently replaced the heating element. Dryer vent has also been cleaned. What could be the cause of this?
  • 159 Answers
SOURCE: Frigidaire Dryer takes too long to dry.
First thing I would do is to take the drum out of the dryer and make sure the back is not all clogged up with lint. That is a very common problem with Frigdaire dryers. The back is where the dryer draws the heat from and it sounds like you have plenty of heat. The only place the heat will go is up and that may be why you are geting burn marks. I wold also clean out the front where the lit filter is that to gets blocked up. I think if you check all that ad clean it out good the dryer should work just fine.
Posted on Jul 13, 2007
aborcass
  • 2651 Answers
SOURCE: Moisture in dryer
you have a clogged vent, somehow your vent has become clogged either with in the hose, or where it exits the house, the moisture being removed from the wet clothes is not leaving the unit. CHECK YOUR VENTING POTENTIAL FIRE HAZARD!!!!!
Posted on Oct 26, 2008
  • 124 Answers
SOURCE: my dryer gets hot but takes forever to dry clothes
Hi, Welcome. Here is your problem.
Two heat temp sensors in dryer. One tells heating element to turn off & on Like your house thermostat but it is set & not adjustable. (More than likely the one going out.) The other is temp Overload to prevent dryer from catching fire. It is recommended that you replace these as pairs.
Posted on Mar 13, 2009
  • 6 Answers
SOURCE: AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Posted on Apr 25, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
Takes 3 cycles to dry clothes even on towel cycle
If the clothes are hot when they come out but moist or damp it mean the moisture is not getting vented, Check your vent pipe for blockages or leaks.
Apr 30, 2010 | Frigidaire Affinity AEQ6000WH Dryer
I just bought a frigidaire affinity dryer and it takes forever to dry things. Some of my loads of clothes/towels have needed more drying time and forget bedspreads. I keep drying them over and over again...
Check the exhaust and make sure the exhaust hose on the back is not pushed back so far that it is closed off and also make sure that there are not a lot of turns in the exhaust hose. This will add time to a drying cycle like you would not believe.
Feb 01, 2010 | Frigidaire Dryers
Frigidaire Affinity Electric dryer E68 error. dries clothes fine, then error light comes on later- after dryer has been off. Will not start unless unplugged for period of time.
Sep 15, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Moisture in dryer
Oct 26, 2008 | Frigidaire FEQ332E Electric Dryer
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer Filter
This is true of all models the lint screen cant be made to tightly woven if it was it would block the airflow too much making the dryer to take forever to dry the clothes.
Jan 26, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Cleaned vent hose, dryer still taking forever to dry clothes.
you have a family of squirrels living in the rest of the vent tube which is leading outside...check vent outside. I once had flying squirrels come into my house through the dryer vent! My dog had a kitten.
Jun 04, 2007 | Whirlpool GCEM2990LQ Electric Commercial...
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
120 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
