Question about Briggs & Stratton Garden
I have an old Simpson's-Sears Craftsman Rototiller. It has been running fine, but suddenly stopped. I noticed there was no spark. I removed the rewind starter assembly and noticed that the flywheel keyway and the motor shaft keyway were out of line by about 15 degrees. I thought this might be enough difference between the magneto and the breaker points to cause the problem. The flywheel was able to move on the shaft because it appeared the key had shattered. When I removed the flywheel, I saw a warning that a steel key should not be used. The pieces of the old broken key were of a non-magnetic material which appeared to be aluminum. Am I on the right track as far as my suspicion about the timing being out because of the movement of the flywheel on the shaft? Is the key I'm looking for an aluminum key and is it a normal Briggs and Stratton part? Why won't a steel key do the job? Thanks Don
    President:
  • Briggs & Str... Master
  • 1,545 Answers
You are on the right track. They use aluminum so that any sudden stop to the crankshaft allows for that little bit of give after the sudden stop to allow engine parts time to slow down. A complete sudden stop could mess up the rods, valves, and possibly the crank itself because of inertia. A steel key wouldn't shear or "break" as easily and would allow for a complete sudden stop. All the engine parts (due to inertia or stored energy) do not easily immediately stop. The aluminum key shears and has a braking effect on the inertia driven engine allowing it to slow down further. Install a new aluminum one (very cheap) and your timing issue there is solved. The replacement key is a very normal, standard Briggs part. They usually shear on a lawnmower when the blade hits an immovable object. I don't know if your machine hit anything. but now you know.
Posted on Mar 31, 2011
Testimonial: "I can't believe how quickly I got a complete answer to my query. I didn't expect it to be there when I checked my e-mail, but there it was, Great!"
  • Roy Cagle
    Roy Cagle Apr 02, 2011
    I am happy that I was able to help you.
My Sears rototiller will only start when I put gas directly in the carberator and then stalls out.
Sounds like you need to clean or replace your fuel lines. (Tubing/hoses) that model is pretty cut and dry with how its set up to pull start. Or maybe the gas in the tank is OLD? Try running a tube from a small can of fresh gas, to the carb. If it runs that's your problem!
May 02, 2010 | Craftsman 8.50 Torque Rating Dual...
I have a craftsman leaf blower which has worked fine till last week when it suddenly stopped. I did a spark test...no spark....replaced the plug....no spark. What next?
How did you do the spark test? Did you use an in-line spark tester? You need to determine definitively that there is no spark and the only way to do it is to use an in-line spark tester...you can get one at Harbor Freight for about $12. After you've checked it that way, if there is definitely no spark, most likely the ignition module is faulty. You should be able to purchase a new module through Sears Parts but bounce the cost and time of that off of the cost of a new blower...you may be surprised.
Sep 10, 2009 | Garden
Sears rototiller wheels locked up engine runs great
After taking the transmission/frame apart, the drive chain for the tires broke and wedged in the case. I cleaned the rest of the gear box and washed all of the gears and sprockets. Ordered up the chain, gasket and grease. I re-installed and greased all of the pieces and reassembled the case. I used a marine wheel bearing grease for the water resistant properties. I installed a zerk fitting right over the shifting lever. This should help keep the grease on the top end of all the gears. After a few hours it is good to go and works just like new.
Aug 20, 2009 | Craftsman Garden
My Sears rototiller model 917293310 is in neutral. It won't shift into any other gear. It starts just fine.
It could be the fork shifter of bracket inside that broke. Check her to get better idea and for parts
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917293310&productCategoryId=1508200&brandId=0247&modelName=TILLER&diagramPageId=00004&componentDescription=TRANSMISSION&documentId=P8120018&backToLink=Return%20to%20Sub%20Components%20list
Jul 18, 2009 | Craftsman Garden
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Craftsman rototiller 3 5 model 917 299130 leaks
Sounds like you are speaking of the float bowl.
It should not have a hole in it.
You could purchase the part from Sears or a small engine shop.
If it were mine, I'd remove the bowl, clean it, and patch with a gasoline impervious material such as JB weld.
Apr 05, 2009 | Craftsman Garden
Rototiller transmission
I am having transmission problem (loud noises). I am looking for a repair manuel for a roper rear tine tiller. Model RT150GR chain drive.
Mar 27, 2009 | Craftsman Garden
Garden Logo
251 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
