Question about Garden
Have a john deere 210le & you can be driving it & the emergency brake will come on by its self happens in reverse more it has arocker switch on the dash, ive by passed the switch, disconnected switches on the brake hyd unit, theres a switch on the rear diff disconnected it & still has problem HELP PLEASE chuck
Hi, I have a 2003 john deere 210le landscape tractor and the brakes are locking it up after traveling about 10 feet. the seat belt light comes on even though the seat belt is fastened. I am unable to find a switch anywhere on the seat and there are no wire's going to the seat.
Posted on Sep 11, 2014
wilsodfarm
  • 986 Answers
SOURCE: hydraulic problem
Check your hydro preasures,pump could be going out,also could be in your relieve valve which will be cheaper,hope that is your problem because of the cost,Sound like you know alot about it, and trust you have a high mechancal ability,I have a hunch it could be in you valve, hope this helps,
Posted on Sep 02, 2009
  • 138 Answers
SOURCE: wanting to by pass seat switch
the seat switch is a safety feature mandated by law. it would be illegal and a liability issue for anybody on this website to instruct you how to bypass the switch
Posted on Sep 26, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
SOURCE: Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Posted on Oct 22, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
I have a John Deere 355d lawn tractor. Every time I engage blade or release brakes the mower dies out. Checked safety seat switch and its not that.
Try pulling up on your PTO switch to engage the RIO switch. If it works then there is a problem with the reverse switch is located near the directional pedals/linkage or on the transmission. Attached is a picture of the switch from the John Deere parts catalog and a wiring diagram.
Feb 13, 2016 | John Deere Garden
I have a john deere 757 Z trak with a kawasaki 25 horse engine , problem is when it is running with the brake on it is fine . Disengage the brake to move it dies when I pull the handles In to move .
Bad emergency brake switch. ..or the brake is not fully disengaging. These units will stall out if you have the brake on correct? Your unit still sensing the brake is on. Check that out first, bypass it by disconnectIno it.
Oct 02, 2015 | John Deere Garden
Brake power booster and what it will cause if its going out
Only get a vacuum leak, if the booster check valve
failed & may effect the idle,not sure if it would be enough
to stall out the motor
What is the emergency switch? Parking Brake warning light?
That wouldn't have any effect on the engine idle
Jul 16, 2013 | 1996 Buick Century
I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
Oct 23, 2012 | John Deere Garden
Where is the battery locqted on a john deere 210le
The steel box directly behind the operator's seat is the battery box. 2 7/16" bolts and the top comes right off. Don't forget positive to positive neg to neg.
May 26, 2012 | Toys
John deer 6400 Shuttle shift will not engauge . I can here a relay activat in the fuse panel. If I hold the lever up the tractor will move forward and the same for reverse. But the lever will not stay...
You have the old style reverser which has been replaced by one that beeps instead of kicking out.These are a known problem with Deere and that is why you can't buy them anymore.The fact that you can hold it in yourself indicates that the enable solenoid and the forward and reverse solenoid are ok and all safety switches are working.You need to replace the reversrer.
Feb 05, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
594 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
