Question about Pacific Image PrimeFilm 3600u Film Scanner
I have driver vsc101u.exe and will it work with win7 or do i need to download a newer version? Thanks, Frank Carlen
  • Pacific Image Master
  • 5,124 Answers
The current version of the driver for the PrimeFilm 3600U is 1.18c. You can download it from here: http://www.scanace.com/support/Cyb_X_SF.htm . This is Win7 compatible.
The only vsc101u.exe for a scanner that I know is for the Umax scanner and is not compatible with Win7. (It was for Windows 98/Windows 2000)
I hope this helps.
(attempting to install the older driver will tell you fairly quickly if it is compatible. Most Win7 installs are 64-bit and the install routine will stop when it hits an unsigned driver (common for 32-bit software).)
Posted on Mar 31, 2011
I need dowland drivers to intel play model APB 24221 99A
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions.
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/QX3-Win7-Files
Step 2. Download and install the QCODINSTL.EXE software from:
Step 3. Download and extract the QX3 Drivers from:
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Before you run the QX3Plus program right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 5. Now double-click on the QX3+ icon on the desktop and the program should run.
Aug 13, 2014 | Intel Play QX3 Monocular Microscope
THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW CAN I FIND THE DRIVER?
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
Oct 03, 2011 | Mitsubishi Color Printer 8000DW Thermal
I NEED DRIVERS FOR SOUNDBLASTER LIVE 5.1 SOUND CART MODEL (SB0100) FOR WINDOWS 7 32BIT THANKS.
http://support.creative.com/Downloads/searchdownloads.aspx?filename=SB24_PCDRV_LB_1_04_0090.exe
there ya go let me know if that helped
Mar 20, 2011 | Creative Labs SB0100 Sound Card
I need the software to run it.
The manual and driver for supported OS versions are here: http://www.dxgusa.com/downloads . The manuals for all of their cameras are listed first and then the drivers. They are listed in order so the DXG-572V driver is in the third line, third from the right of the driver section.
The driver may not have been updated from the original which for Windows XP/ME/2000/98SE. In Windows Vista 32-bit the driver may work or the correct driver may be in the OS. For Windows 7 32-bit, use the driver built into the OS. (Microsoft's compatibility center provided the information.)
With the 64-bit versions of these newer versions of Windows, the compatibility is unknown. However, the driver from the DXG site will probably not work without the compatibility mode, if it works at all. For compatibility mode, right click on the exe file and choose Properties, select the Compatibility tab and set it to run as Compatible with an older version of Windows. Then right click and Run as Administrator. Otherwise, keep it on a computer with the older OS, use a dual boot with the older OS or a virtual computer with an older version of Windows. With Win7 Pro or Ultimate, you can use the XP mode for a free virtual computer. (Download and install Microsoft's Virtual PC and then XP mode; install the camera to the virtual computer.) All other methods will need a licensed version of an older version of Windows. The only issue with the virtual computer is that files can't be shared between the two computers directly. Put them on external or optical media to share them with the real computer.
I hope this helps.
Dec 14, 2010 | DXG Technology DXG-572V Digital Camera
Autodesk DWG TrueView software cannot be installed in a Windows 7 Professional System
Which version are you using? You may need a newer version due to changes in the Windows OS over time. Autodesk has a 2011 version that is Win7 compatible for all versions of Win7 except the Starter edition. You can download the software from http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112 . Fill out the form reached by clicking the download link if you have Win7 Pro 32-bit. Otherwise, click on the link to the 64-bit version for the form to get the correct installer.
I hope this helps.
Dec 04, 2010 | Autodesk DWG TrueView
How can i find audio drivers suitable for Intel(R) Pentium(R) Dual CPU E2140 @ 1.60GHz for windows 7
hello,
i can help u get the link to the download page, from there you need to download the file and install it in your notebook,
click or copy the link and paste it in the address bar.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/17aud08us24.exe
hope to have solved your problem
good day
Jun 22, 2010 | Lenovo 3000 Y410 Notebook
My print master not print with window7 thank
Printmaster needs to have new drivers or be replaced with the newer version that will address printers. Contact Broderbund for information on release of the print drivers for Win7
Please rate my help++++Thanks for using FIXYA
May 07, 2010 | Broderbund PrintMaster Platinum 16
I got a new computer and I need to install my
You can download the drivers from Dell's support pages for some OS's (I see a WinXP, Vista 32-bit and Win2K.) If your new computer came with Win7, you may not have much luck unless you use a work-around. Dell's site indicates that the Vista driver doesn't work in Win7. You can try the compatability mode to install the driver (download, extract the files to a new folder, find the .exe file and right click on it. Choose Properties and then the Compatability tab. Check the box for Run as and choose the correct OS version. Then right click again and choose Run as administrator.) Alternatively, Win7 Pro and Ultimate can run a virtual XP computer (on some computers). It takes two downloads and installation of the programs from Microsoft. Then install the printer using the XP driver from Dell.
The drivers are available here: (long URL)
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=PRN_ALL_A924&hidos=WW1&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
I hope this helps.
Mar 14, 2010 | Dell 924 All-in-One InkJet Printer
Download copy JFSW.exe for JetFlash elite
Driver Installation – Windows® Me, 2000, XP and Vista
No drivers are required. Newer Windows operating systems have built-in drivers that support the JetFlash®. Simply plug your JetFlash® into an available USB port and Windows will automatically install the files needed to use your device. A “Removable Disk” with a newly assigned drive letter will appear in the My Computer window.
JFSW.exe is the older version. You might want to try JetFlash Elite v2.0, a newer more advanced version of JetFlash elite - highly recommended:
http://www.transcendusa.com/Support/DLCenter/Software/Setup_JFSW2.exe
I think you know about this page, but here's a link to save you googling:
/index.asp?axn=SRH2&ModNo=107&ItemID=TS2GJFV30
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Transcend T.sonic 610 MP3 Player
Pacific Image PrimeFilm 3600u Film Scanner Logo
238 people viewed this question
Top Pacific Image Office Equipment & Supplies Experts
Willem.
Willem.
Greg Cann
Greg Cann
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
