Question about Kenmore Refrigerators
The refrigerator is not cooling. it is plugged in and the lights all work. it makes a noise like it wants to turn on, but its not cooling
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
It could be a number of things so the problem will need to be narrowed down. The place I would start is as follows, making sure the compressor itself is coming on/operating.
The noise you alluded to, "it makes a noise like it wants to turn on, but its not cooling" is it like a "clicking" noise following a low "humming" or "buzz" when the compressor is perhaps trying to start ?
If you feel like you can trouble shoot further I`ve provided the following info to assist you or you may decide to call a professional appliance technician...it's your call.
I don`t know the age of your fridge, but I should mention...
** Most of the manufacturers of fridges ( including Kenmore/Sears ) have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to.**
If you have a multi- meter you can check the compressor to see if the windings are ok.
**First, Unplug the fridge**
Remove the panel at the back down at the bottom. This should gain you access to the compressor.
On the side of the compressor will be the start relay/overload assembly such as this image...it may be enclosed in a black plastic cover as well.
Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1the refrigerator is not cooling. it is plugged in - 775ec2d.jpgt.
i.e.
The above package contains info and hardware on how to connect it.
NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relied on for long term reliability or safety, but rather thefactory replacemnet, double check with your model number.
Hope that help`s move you forward if nothing else. If so please take a second and rate the guidance and a testimony to your inquiry you received here at FixYa, either or all is appreciated.
Let me know if the compressor is indeed operating yet the fridge or freezer fail to cool and I'll continue to help in any manner I can. Good luck
Regards,
Macmarkus :)
Posted on Mar 31, 2011
  • Conaway Apr 26, 2011
    Same problem for me. Lost power in the St Louis storm friday. Power came back on and now click/buzz no compressor and it keeps trying every few minutes. I turned off then unplugged for about ten minutes to let the pressure equalize but no change. I will try with meter like suggested tomorrow. Kenmore 2001 bottom freezer.
  • Keith Apr 26, 2011
    My Kenmore frigerator (mod. 25337877892) ser.#BA91107977, has stopped cooling although I can hear the motor running when i turn the cold adjustment switch. The freezer part works fine. Do you think the information above may help my situation? I will try it. Thanks, Keith
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
Refrigerator not cool
If the freezer is cold but the refrigerator is warm, it is probably a defrost problem, see>>> Refrigerator Defrost Parts .
If the freezer and the refrigerator compartment are warm after the unit has been plugged in for at least an hour, it may be a different problem. Does the refrigerator sound like it is running? If not, have you checked the fuse/breaker box in your house?
Check to make sure the refrigerator plugged in, and the cord isn't damaged, the lights are on inside the refrigerator, the temperature dial is at the proper level, there is a normal "running" noise coming from the back of the refrigerator (no rattling or burning odors), and it isn't giving off a strong and unpleasant smell (coolant leak). Check here for help diagnosing possible problems >> Refrigerator Parts Cooling .
Apr 01, 2014 | Whirlpool Refrigerators
Bottom fridge has stopped working. Top freezer is okay. Fridge light is working and thermostat is making operating noise, just no coolness.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 26, 2011 | Avanti FF510 (5.1 cu. ft.) Top Freezer...
Refrigerator is not cold, freezer is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 26, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
Ac dose not really work very well and when i turn the wheel ths jeep make noises
When you turn the steering wheel and it makes a whirring noise, check the power steering fluid level. As for the aircon, make sure the setting is on cool, a/c light is on, on switch and that airflow is good. If it is still not cool after running for a couple of minutes, have refrigerant checked.
Jul 11, 2009 | 1994 Jeep Grand Cherokee
Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Dec 27, 2008 | GE Refrigerators
Side by side not working
Make sure the compressor is running and not just a fan motor.
Unplug the ref for 30 min or so and while you are behind the ref plug it back in, listen for the compressor to start. If you hear a clicking noise and the compressor never starts then replace the relay on the compressor. If the compressor runs and still does not cool then you may have a coolant problem.
Dec 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
230 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
