Question about Mitsubishi WS-65903 65" Rear Projection Television
3d glasses only work in one eye - Mitsubishi WS-65903 65" Rear Projection Television
  • Mitsubishi Master
  • 3,459 Answers
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid ch3d glasses only work in - 65af323.jpgbr />3d
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Posted on May 09, 2011
Tip
How to make your photos 3D with normal camera
<p>3D images are interesting, but they depend on glasses, the way the left and right eye images to observe. This technique of creating cool 3D image does not require glasses, but still produces an illusion of 3D. <br /> <p><br /> <p>Instead of two images and combine them into one image with each highlighted in red and blue or cyan and magenta, or a different color for anaglyph images, both images are animated and "wiggle" back and forth, which creates the illusion of depth. <br /> <p><br /> <p>All you need to move a stereoscopic image becomes two pictures taken from a location about four inches apart or more for the positioning of the human eye to follow. You can combine images into one, the more traditional way would be to create an animation GIF file you may use GifNinja it is a Web based application to convert photos and videos to Gif animations.Go to gifninja.com<br />
on Aug 08, 2011 | Cameras
DLP D9 VIVITEK PROJECTOR
Sounds like the color wheel may be bad
Nov 18, 2013 | oneworld_china Active 3d Glasses For...
Visio LCD LED 3D tv how do you watch tv in 3D?
For the M3D420 Vizio TV, you need a 3D source connected to the TV with an HDMI cable that supports 3D. Some older HDMI cables will not carry all of the data of a 3D source. Turn off the set top box (for example a 3D Blu-ray player). Set your TV to the correct input (press the Input button on your remote). Then turn on the set top box and (for the Blu-ray player) insert your 3D content disc. Start playing the movie. When you see the prompt "3D content detected", highlight Yes to switch to 3D display and press OK to start the 3D playback.
After selecting Yes and pressing OK, then put on your 3D glasses. Make sure that you are sitting with your eyes level with the TV screen eye-line and looking straight at the screen. (If you are off-line, you will not get the 3D experience.)
These directions probably apply to all 3D Vizio TVs. I hope this helps.
Dec 28, 2011 | Televison & Video
Hi, how can I check if my 3D glass's are working ?
@nah9
You can tell if you're 3D glasses are working if you can see if the images in the movie or the game that you're playing pop-up in and out and you can see a depth and float as you watch.
If you have a 3D enabled PC, you can test it yourself by running a sample stereoscopic 3D test application here. You could also find additional information here.
Cheers
Sep 03, 2011 | LG 3D Glass (1 Glass and 1 Emitter) Video...
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
3D doesn"t work
You will need a 3D-capable or 3D Ready tv. The difference is the 3D-capable tv will require you to buy a piece of equipment called an emitter to connect to it. The 3D Ready tv already has an emitter. You will also need a 3D bluray player or Playstation 3, 3D glasses, and hdmi version 1.4 cables. You will need 3D glasses and 3D bluray Dvds. If you want to watch something besides bluray dvds you would have to subscribe to direct tv as they are now offering some 3D broadcasting.
Jun 15, 2010 | Philips DVD724AT DVD Player
SONY KP-61HS30
Sounds like it needs convergence chips. This repair requires test equip. and soldering/desoldering tools. Most repair shops charge between 200.00 and 400.00 to do this repair on your model of tv. Hope I have been some help
Mar 03, 2008 | Sony KP-61HS30 TV
Televison & Video Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
