Belkin (AP3080010) UPS System Logo
Posted on Mar 31, 2011
How do i remove old batterries from belkin ap30800-10
Had the starter repaired now whenI start the car it tried to turn over once,now all I get is a clicking noise,could it be my battery?it is 14 years old
if the wires were fitted correctly to starter then yes change the battery ,14yrs old on original battery is a record but yes some of these toyota batterries are exceptionaly good though
Colud yo please help me i have a belkin router installed but i on to change it to a different belkin router every time i tray to install new router ,message comes up can not find new router, do i have to...
1.Yes, you have to save the configuration of the old router to see where you have it .
(print this out so that you understand the configuration.)
2. Uninstall the software for the old Belkin router.
3. Connect the new Belkin to the computer
4.power the computer off / leave off for (2) minutes then turn on.
5. Run new installation software on the new Belkin router.
Installed a new Belkin N router in our office. Most laptops on wonderful vista. Some connect local and internet some only local. Tried restarting and removing old wireless on computer. Any other...
You did all the possible troubleshooting steps... Try to disable the firewall and Anti virus programs or Firewall programs if you have.... and check it
I havea packard bell imdeia and the bios are messed up
i cannot be sure because i have never seen inside this type of computer, but it should be the same as any other.
on a normal motherboard there are 2 ways to reset the BIOS, the first of these is to remove and then replace the cmos jumper. the second is to remove the cmos batterry wait 5-10 minutes and then put it back into its slot.
i prefer the second method as it is easier and removes the confusion and mess of jumpers.
once the case of your computer is off the cmos batterry should be easy to see, it looks like a watch batterry and is about the size of a 10 cent peice. normally you will require a small flat head screew driver to remove the batterry
1helpful
How do i remove the alternator on my 2000 volvo s40 with out removing the radiator
turn off radio.remove negative batterry cable remove drive belt power steering pump.set a side do not disconnect.then remove alternator and its electrical connectors then remove alternator.
Sony t30 LITHIUM BATTERRY
It is possible that the battery is defective. This is a common cause for what you are describing. To verify this, you will have to try another battery. You can take the camera to the nearest Sony service center to verify this if you don't want to try a new battery first.
Jerry G.
1helpful
Not charging
maybe the batterry in the phone, the connector will nto hold charge, either your batterry is stuffed or the charger is, it has nothing at all to do with the phone, or either the phone connectors that run leads to the batterry, the little gold clips that the batterry connectors go to, arefaulty and that means you will have to replace the phone.
Oct 25, 2008 • Nokia 1100
1helpful
2answers
Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
Error Printing to LPTUSB1 for the printer Brother Hl-1230 series
Connect the device to a different usb port. Download the newest software/drivers from the Belkin web site. Remove the old software and install the newest downloaded version. Please supply the error.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
