Question about Husqvarna Rose
What does the flashing circled E on the info display mean? and how do we get it to continue to embroider? it seems that the design is off to the right and it wants to embroider outside the initial square stitch.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
The flashing E means the design is either too big for the sewing field limit (about 3.93 x 3.93") or not centered. From the sound of your description, most likely the design is not centered. Check the design size in software and center it before transferring to the card.
Posted on Apr 26, 2011
Need help using flash stick to download embroidery designs from computer and what they are jef, emb,
.Jef and .Dst will work on a Janome machine. You can buy designs per the hoop sizes for your machine. Buy, download, and transfer received file to a USB drive to transfer deign to machine.
Cheers,
Embroidery Services
San Diego, CA
May 28, 2016 | Janome Memory Craft 9000 Computerized...
Will not sew continuestly when im embrodering when i press the reverse button
It is completely normal for a Bernina 180 and other Bernina models to stitch just a few stitches and stop after first pushing the reversing button. The reason for this is so you can cut off the extra piece of top thread so it does not get caught up in the embroidery design. After you cut off that extra piece of thread, press the reversing button (hold it in till the machine starts) then it will continue with the design. Assuming you do not have a problem (a message would come up on the screen) or you are out of bobbin thread, the machine will continue to embroider till either the design is finished or it stops because you need to change the upper thread to the next color. Each time you start to embroider it will stitch about 3 or so stitched and stop. Cut off the extra thread and press the reversing button again to continue.
If this is not the problem you are having then you need to describe your problem better, in more detail.
This should help! Bill
May 26, 2015 | Bernina Artista 180
Why won't my baby lock ellure plus read my USB stick....I copied a pattern from the internet ...it seems to have read the pattern but when I put it in the sewing machine it comes up P1/P1
You downloaded a toyota dst file. The babylock will embroider the design but it wont display the design or any picture or attributes. It will sew it, but try on scrap fabric first to be sure.
Aug 12, 2013 | Baby Lock Sewing Machines
Does the futura software from compucon allow you to wind the design forward so you can upload the design to the machine, and can continue embroidering the design to complete it. Reason why is had to...
You can skip color blocks that you have already embroidered. When you get to the one you were working on when the machine was turned off, send it to the machine and use the needle down button to advance the design to the point when you stopped. Then you can hit the green button and proceed.
Dec 04, 2011 | Singer CE-200 Quantum Futura Computerized...
I have a designer 1. recently when i go to embroider, it starts fine then just goes hay wire and put teh embroider all over the place- not like the pattern. Sound to me like the emb. unit? thanks kathy
Hi Kathy, I'm sorry your Designer 1 is not feeling well.8*( It sounds like to me you need to get your embroidery unit re-calibrated by your local technician. When was the last time you had your machine serviced? Are the designs you are trying to embroider stock designs or your own designs? Have you tried resetting your machine by turning it off and back on again and let the machine calibrate again? (Take the hoop off before you do this and put it back on after you have selected your design) and try it again. Also how old is your machine? They had a recall on Des 1 purchased between 1999-2004 for a power supply problem. The serial # and recall info is on the Viking website at- www.husqvarnaviking.com. Also do you have enough clearance around your machine where the hoop is not hitting anything while it's embroidering that will throw it of big time! Hope something here helps you! If I can help you further you can also email me at- kats2sew@hotmail.com Happy Sewing!! Kathy ( from 1 Kathy to another)
Nov 02, 2010 | Husqvarna Designer I
I am ready to embroider and a flashing hoop icon on my viking rose and then it beeps. What does this mean?
Refer to your manual, it could mean the hoop is not making contact with the sensor or you are using the wrong size hoop for the selected design.
May 19, 2010 | Husqvarna Rose
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
How do you use the Plus Hoop on a Husqvarna Viking "Rose" Sewing Machine?
The plus hoop is a multi positional hoop that allows you you to embroider designs up to 4" x 6". It is essential for monogramming and lettering using your Rose. The Rose hooping system is the same as the 1+, the Scandinavia 300 and 400.
The designs you use must be formatted for the plus hoop. That is, the design has already been divided into two or three elements. Each element is an individual design. For instance, say the design is a long stemmed rose. It would probably be divided something like this: design 1: the flower and the top part of the stem, design 2: The middle part of the stem and the leaves, design 3: the bottom part of the stem.
You would hoop up your fabric to be embroidered, attach the hoop to the machine, set the hoop to position 1, select design 1, stitch out design 1, set the hoop to position 2, select design 2, stitch out design 2, set the hoop to position 3, select design 3, stitch out design 3. You should have a complete design when you're done and everything should match up perfectly!
The hoop is divided up into three squares, 4" x 4". Position 1 square overlaps position 2 square and position 2 square overlaps position 3 square. This overlapping allows the designs to stitch out more smoothly.
I hope this helps. Let me know if you have further questions. Carrie
Aug 27, 2008 | Husqvarna Rose
Sewing Machines Logo
138 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
