Question about Coby DP-772 Digital Picture Frame
DP850-1G I deleted the vividshare file on the frame and now my pictures arent showing up on the computer to upload to the frame
Pandigital picture frame manual
Unfortunately, there is no way to permanently fix the sideways photos while in the photo frame device. The only way to permanently fix them is to rotate them in your computer, and save them that way in the computer then re-upload the corrected pictures to the frame. Oh ya, you will have to delete the un-rotated pictures from the frame also.
Note: if the same name is used in both spots then the frame will take the newer one when it is overwritten on the upload to it therefore you will not have to go back and delete them manually!
Good Luck!
Rich Lilja
Jan 06, 2014 | Photography
How can i wipe the memory
You'll need a computer to do this.
1. Turn on the digital frame.
2. Connect it to a computer via the USB cable.
3. On the computer, click on the My Computer icon.
4. The digital frame should be listed under Removable Devices - probably as Removable E or Removable F.
5. Double click on the the device.
6. Select the file you wish to delete.
7. Press the delete key on the computer keyboard.
8. Click Yes in the dialog box.
This will delete the picture.
I hope this would be helpful.
Dec 07, 2011 | SmartParts SPX8 Digital Picture Frame
I inserted a thumb drive with pictures on it and although they show on the frame, they do not show in the order that I numbered them in
The following advice is not specific to your model, but you have a common problem and the solution I suggest usually works for most makes and models.
Try renaming the files in the order you wish them to play as 001, 002, etc. If you do so without the leading zeroes then on some models of picture frames the filing system gets the images in the wrong order. Note that if you are uploading thousands of images then you may wish to start the numbering at 0001 instead. After renaming the files, re-upload them to the photo frame and you should find that they're OK. Depending upon your host computer's operating sytem you should be able to batch rename the files instead of laboriously renaming and saving each one individually.
Aug 21, 2011 | Quantaray 7-Inch Digital Picture Frame -...
Hello, my name is eusebiu. I have received an akai photo frame, the model ADPF09XN. The problem with is that it does not see any of the files that i fave uploaded on the memory stick. The frame sees the...
Were the new files the same type as the old ones? Could be that the frame cannot read the sort of file you are now introducing on the stick. Load standard jpeg files onto stick and see if it then works. If it does not, then something may have happened to frame rendering it useless.
Jun 17, 2017 | Computers & Internet
Have a new 8 gig memory. Shows full before all pictures load, should have loads of room?
I would format it using your computer, then try loading in your photos again.
In Window, go to your file explorer, right click on the drive and click Format.
http://www.blogsdna.com/wp-content/uploads/2009/01/format-usb-drive.png
It's ok to do a 'quick format'.
This will delete everything on the drive.
Now try loading on your photos, and see if that made a difference.
Mar 07, 2011 | Philips 7FF2CMI/00 Digital Photo Frame
I can't delete pictures from my Smartpart Omintech photo frame.
I had the same problem. I "thought" I was deleting them via my computer (using the delete function in Windows Explorer). However, that doesn't really delete the files.
I had to manually delete 82 photos (one by one) using the klunky menu buttons on the frame. I hope it works. Note that the frame cannot be connected to your computer when you're doing this.
Jul 24, 2009 | SmartParts (1DPFSP01) Digital Picture...
Comp does not recognize the connection
There was a corrupt file on the picture frame that needed to get deleted. The corrupt file was not allowing anything to work properly.
May 07, 2009 | SmartParts INC. digital frame. 7.0 in....
SmartParts Frame SPX7E only allows me to load 165 photos
2 answers...
To remove a picture, connect the frame to your PC via USB. you should see the frame appear as a drive, in my case,
36972 (E:)
open the drive as Explore, you can now see the pictures, and delete what you no longer want.
you can download the software from
http://www.smartpartsproducts.com/content/support/optipix/index.php
Nov 27, 2008 | SmartParts (1DPFSP01) Digital Picture...
I can't figure out how to delete individual pictures from display
The photo frame's interface doesn't provide any file management, so you can't delete, copy, move, or rename files on the display itself. Why can't you delete files on the card using your computer?
As for the problem with cutoff heads, etc.. Spend some time on your computer to make all your images in 640 x 480 pixels in size and save them all in .jpg format. This should solve your problem and makes the display work quickly.
Nov 23, 2008 | Polaroid IDF-1030 (826219006783) Digital...
Upload images to SD card
I just purchased a frame and wondered the same thing. My computer has a slot for an SD card once inserted the computer shows the SD file. Then go into where you store the pictures highlight the picture one at a time in the picture file my program says copy to file click on it and shows the SD file as F file click copyit then downloads to the card. Done put SD card in frame worked perfectly.
Dec 18, 2007 | Nikon Coolpix 3200 Digital Camera
Coby DP-772 Digital Picture Frame Logo
187 people viewed this question
Top Coby Photography Experts
richie46
Are you a Coby Photography Expert? Answer questions, earn points and help others
