Question about Sanyo DRW-1000 DVD Recorder/VCR
Sanyo drw 1000 dvd/vcr recorder Have used this machine on n off for years. I use Verbatim DVD-R disks and have had no problems until recently. Recently, when a timed recording ends regardless of the length of recording and the unit set to 'LP' for recording when I turn it back on it tells me there are '00:00' time or space available on the disk and therefore will not allow me to record additional programming. It does this regardless of the length of the recently recorded program i.e. 30 mins, 90 mins etc. There should be a total of 4 hours available and I have recorded multiple programs on the same brand disk in the past. I have already tried to unplug the unit and allow it to set and I have already attempted resetting it back to 'factory settings' I have read and re-read the manual looking for any other 'setting' that may effect the number of times you can record to a DVD-R disc but no luck
  • 2 more comments
  • galwaychase Mar 31, 2011
    no the disc(s) are not finalized and still require that step after I turn the burner back on ... i.e. I will load a 4.7 GB disc set the record time at LP which is the longest play and that gives me an inital max time of 4 hours ... set the record time and regardless of duration when I come back later and turn the unit on to schedule another program I am told there is no space remaining on the disc and in the setup menu the disc is still (un) finalized. The manual specifically says that DVD-R discs can be recorded to as long as space is remaining and I have recorded multiple programs to the same brand discs before ... also I had several Maxell DVD-R discs sitting around and recorded to one of them with exactly the same problem.
    yes and when using DVD-R discs the player automatically initializes to 'Video Mode' and will not allow you to select 'VR mode' for the discs (only available for RW discs) but just in case I have gone into setup and made sure that the VR mode was set to LP as well and it made no difference
  • galwaychase Apr 01, 2011
    ok I will have to dig up a DVD-RW ... as for using the DVD-R discs there is NO 'unfinalize' option to choose and there is also no 'finalize' option available anywhere that allows you to select it for auto-finalize the only finalize menu option is in the setup menu under dics and you have to manually access this 'after' a recording has been made
  • 4,889 Answers
I have a feeling that you have choosen the setting to finalize the disk and that is why you are not able to burn anything into the remaining blank space. I suggest you cross-check that the particular option has not selected so that you can record multiple sessions on the same disc.
Posted on Mar 31, 2011
  • 1 more comment
  • eagle338
    eagle338 Mar 31, 2011
    Ok. Are you sure you are the recording mode is "Video mode" and not "VR" mode? I have seen the VR mode cause problems on certain recorders so please cross-check its in the Video mode and let me know
  • eagle338
    Ok. Those are the only 2 settings affecting this. So lets verify if you are able to record multiple sessions on a DVD-RW. If you are not able to do so choose the un-finalize option and see if you can record again. This will help us figure out if its finalizing the disc even though you have chosen not to!
  • eagle338
    eagle338 Apr 01, 2011
    Yes the un-finalize option is not available for DVD-Rs. That is why I suggested that you use a DVD-RW.
Sanyo DRW-1000 DVD Recorder / VCR Combo remote control
I thank you for your interest in helping me. However, I just want to know where to get a replacement for the remote control for a DVD RECORDER VIDEO CASSETTE RECORDER COMBO, model DRW-1000. Then, I do not find necessary to pay for such information. Thanks, again, anyway for your help, sincerely,
Juan B. Pérez-Valverde
Jun 17, 2009 | Sanyo DRW-1000 DVD Recorder/VCR
Need manual for drw-1000 DVD recorder
hi!u can get the manual from this link
http://www.retrevo.com/s/+Sanyo++DRW-1000+DVD+Recorder?sub.x=0&sub.y=0
if the link doesnt work,please make a free account at retrevo.com and download the manual
hope it helps!
Nov 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Sanyo DVD/VCR Recorder/Player
How do i conected via sky+ to watch programs and record by telli
Mar 17, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
SANYO DRW-1000 DVD/VCR COMBO
you must use R-, RW- to record on this unit
Dec 28, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
Sanyo drw 1000 dvd recorder
bad laser or needs to be cleaned
Dec 06, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
DRW-1000 Sanyo DVD/VCR combo
go to web site http://www.retrevo.com/s/Sanyo-DRW-1000-DVD-Players-review-manual/id/311dj889/t/1-2/ when it opens, click on download the manual (it's a PDF) I copy/pasted to my computer files. It's about 60 pages worth...............Hope it helps.
Aug 31, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
Jun 03, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
Owners Manual
I have a manual - what do you need to know?
May 02, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
What kind of dvd's can be used in this dvd player?
That will write on -R or -RW ONLY ... for +R or +RW disks, it can read but not write. You can see this on the recordable media section on this page: http://www.dealtime.com/xPF-Sanyo-Sanyo-DVD-DRW1000-Recorder-Hi-Fi-VCR-Combo
Apr 23, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
Sanyo DRW-1000 DVD Recorder/VCR Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
