Question about Cell Phones
How to take apart my phone and change the top flip side with screen
2 Suggested Answers
Chinthakaj
  • 416 Answers
SOURCE: replace the flip sreen
you can try this link
http://www.prism.gatech.edu/~ccastkd/Krappy/V3%20Dismantle%20Guide.pdf
Posted on Mar 24, 2009
Sanyo flip phone screen going out
Typically with flip phones there is a wire connecting the screen to the board. This could just be loose. I don't know in your phone but in Razors this wire can just be popped back into place if you feel comfortable taking it apart. Easy to do through Youtube videos
Mar 29, 2014 | Sanyo r Sanyo Mirro SCP-3810
How do i replace flex cable on a razor phone can u show video
Ok..#1.take the battery out..
then youll have to remove the 2 screws that hold the modem part of the phone in.gently pryup on the modem ,on the side with out the usb charger port..slip a thin flat tipp screw driver in there and slide it towards the bottom of the phone. there are littler plastic clips carefull not to break them.then youll see where the bottom of the flex cable plugs in.unplug it.then flip the phone over,in the 4 cornors of the screen side of the flip there are tiny little rubber plugs. pop them out and undo the screws in there.near the top of the screen there is a little slot on the right side of the screen ..gently pop the cover off the screen..unplug the flex cable from the screen.and carefully remove the screen.be careful not to damage the buttons on the sides of the screen.then close the flip and turn the phone over..looking into the battery part of the phone,on the top right hand side of the hindge there is another little screw,remove that.then again turn the phone over and stick a flat tip screw driver into the open hole and pop the chrome roller out.then very carefully youll be able to seperate the 2 halfs. look on the back side of the keyboard youll see little metal tabs folded over that holds the key board in place..the keyboard and the flex cable are one piece, just revers the procedure to replace.." BE VERY CAREFUL RUNNING THE FLEX CABLE THREW THE HINGE AS IT CAN DAMAGE VERY EASLY." IF YOU NEED MORE ASSISNT CONTACT WWW.PHOENIXTEC.CA they are very helpful
May 11, 2010 | Motorola Mobility RAZR V3
How do i change the housing on my 6500 slide mobile
You need a T5 screwdriver and a new housing... Use an Original housing, copies dont usually fit right... 1, Remove Back cover and Battery. 2, Remove 4 T5 screws at the back of the phone, run your fingernail/opening tool around the housing and it should come away a little, dont pull it apart as there are 2 ribbons one for the Screen the other for the keypad. 3, Turn the phone over and run your fingernail under the keypad. 4, Carefully take the bottom half away with the phones PCB still in the bottom housing, using a flat screwdriver carefully lift off the two Ribbons 5, You can then remove the keypad from the top part of the phone, this is stuck on by double sided tape pull downwards, there are 2 spring loaded pieces on each side. 6, Remove the 4 T5 screws, 2 under where the Keypad was and 2 at the top 7, Again using your fingernail or a opening tool run around the edge and the screen part should come apart, dont damage the ribbon You now have the phone apart take out the bits and change what you like :)
Jun 10, 2009 | Nokia 6500 Slide Cellular Phone
My blackberry pearl flip got wet
Sorry to tell you but the back light on your blackberry pearl probably burnt out. That is one of the most common issues with a wet phone.
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Checkout the guide I wrote for replacing the blackberry flip LCD displayscreen. There are also links to by the new pearl flip LCD screens2.gif
Blackberry Flip 8220 LCD screen Replacement Guide
May 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Popped screen
It is actually not that complex. Remove screws pull apart cover, there will be a couple more screws for you to remove. The you will see the plastic wire strip leading from screen to the circuit board. This strip just slides/pulls out. The screen pulls off. Reverse for replacement.
Good luck finding a replacement. The company's won't sell an individual one for the general public.
Jan 29, 2009 | Samsung Cell Phones
Nextel i880
my phone does not display menue anymore
Jan 15, 2009 | Motorola Mobility i880 Cellular Phone
Top flip section of phone broken,
Yes you can do this but it is safe to take the phone to a mobile repair shop and have them repair it for you.
Aug 14, 2008 | Samsung SCH-u740 Cellular Phone
No display
there is problem with ribbon of ur phone , which connects upper flip part which includes screen , with lower part of ur phone, it need to be changed take it any technician
Dec 24, 2007 | Sony Ericsson W710i Cellular Phone
Motorola v3
take apart the top half and reseat the cable going to the flip
Sep 25, 2006 | Motorola Mobility RAZR V3
Cell Phones Logo
107 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
