Question about Fire Magic Echelon E1060s2E1P51 Stainless Steel Propane Grill
I have an E1060 drop in. The unit was purchased three years ago, but major delay in construction. Installed a couple months ago, all was fine. Have yet to cook on this grill. Two weeks ago, went to use, and motorized lid won't work, by either remote or stationary switch. Control panel, lights and ignighters all working. Thinking someone forced lid open. Took motor apart, no broken gears. Any ideas?
    Brigadier General:
  • 4,736 Answers
Dan, did you check the circuitry and relays to the motor, as was suggested on March 29th? If the motor can't get power it won't work. It seems, that this may be the problem, since you took the motor apart and there were no broken gears and all other electrical devices work. The other resolution was to contact R.H.Peterson Company, the manufacturer for more information, if all else failed.
Posted on Apr 01, 2011
I have a Corcho portable gas heater that I have had for years and it has been really reliable, however it doesn't seem to be working correctly!!
Many times when changing bottles you may have to ignite it several times until the air gets out of the line.
Dec 12, 2015 | Heating & Cooling
No Hot Water
Hard water contains a lot of minerals and depending on how hard the water is also depends on how often you must replace the filters. A much better alternative is to have a water softener installed before your hot water heater and any other sorce of domestic water supplying your home. I have one and it works great. Just be advised that you will need to replace the salt crystals every couple of months depending on the time intervals you set the timer to. If you find that the water still remains soft after two months and your filters are not to badly clogged then you may try adding salt every three or four months and see if that solves your problem. You also have to remember that your also using the water for drinking cooking and bathing so softening your water supply is very important especially if you or anyone in your household ever had any kidney stones or kidney problems.
Good luck,
Marty
May 08, 2014 | Navien CH-240-ASME-LP, Combi Condensing...
Goodman ck36 1b a/c. Capacitor replaced 2 years ago. Unit is 13 years old and thermostat is Honeywell, also 13 years old. This summer there seems to be a 3-5 min delay (from when thermostat registers call)...
If you have a AC unit with electric or gas its doing what its supposed to do, let the pressures in the system equilize before starting again, If you have a heat pump its doing it there as well you just have not noticed. Anti cycling is a good thing, 4 to 5 minutes is normal.
Jul 05, 2011 | Goodman Heating & Cooling
I just got my 1490LMT, I went on line and updated the maps then I put in a local Costco store where I knew the highway construction had changed this from a complex turn off the highway and make two loops...
I have the 1490LMT also and all the maps I have found on this unit and others are usually a year behind or more with new road changes. That is why I bought a LMT unit, because I did not want to pay for outdated maps on my 265WT any longer. This is a problem with most Gps units sold. May be if more people write to Garmin and complain they may do something. I have attached a link to Garmin for you to let them know.
http://www8.garmin.com/contactUs/
Thanks for using FixYa.
Jun 18, 2011 | Garmin nuvi 1490LMT GPS Receiver
I have a HTC Desire that I bought before 8 months on Three Network from United Kingdom.Now I have moved to a different country but my cellphone seems to be network locked.How can I unlock it now?
I bought my HTC Desire from Three Network about half a year ago. Just a couple of days ago, I called Three at 333 to get my unlock code. It took about half an hour to verify me and my credit card details. I suppose you could call their international number at 00447782333333. It costs me 15.32 pounds to unlock.
Pay As You Go user.
Mar 01, 2011 | Cell Phones
I purchased a very nice and expensive jacuzzi 60 X36 shower base in oyster and had it professionally instlled in new construction a little over three years ago. A week ago when using the shower I heard a...
some shower bases require additional support,I would call jacuzzi and explain the problem.If 6the unit required more bracing you will probably have to reach the contractor who put the unit in,then go from there,but this day and age it is hard to get satisfaction cause no one wants to be liable for labor and product.good luck hope you get satisfaction from one or the other!
Jan 25, 2010 | Jacuzzi T362-969 Tru-Level 42 X 36 Shower...
This problems has happened two times in the last 2 months. When I put a CD in the player it plays fine. I stop somewhere, turn the car off, with the CD still in the player and when I restart the car the...
There was probably a bad connection to the power supply. There are three wires. RED is battery(12 volts at all times)YELLOW or ORANGE is acc.(12 volts when key is in acc position) BLACK is ground(connected to any metal part of the car). Pull out the stereo and make redo these connection and makes sure they are right this time.
Aug 11, 2009 | JVC KD-G230 CD Player
Leaking Noritz water heater.... I have a Noritz N-069m water heater. When i purchased the unit 3 years ago, i was told that if i installed a water softner unit it would void the warranty. A year and a half...
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech scott@bridgeplumbing.net
Jul 27, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Bulbs burning out in Hampton Bay ceiling fan
I would suggest getting an electrician to check the current running through the wiring. I had installed a similar fan in my grandmother's house a couple of years ago and had the same problem. After a couple of months of constantly changing bulbs, I brought in an electrician to check the current and found that there was a short in the wire which kept causing just enough of a current surge to blow the bulbs.
Nov 29, 2008 | Hampton Bay 04345 Cruiser Ceiling Fan
Fire Magic Echelon E1060s2E1P51 Stainless Steel Propane Grill Logo
109 people viewed this question
Top Fire Magic Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
