Question about Gateway M-7351u Notebook
Device audio not working - Gateway M-7351u Notebook
    Genius:
  • 1,542 Answers
Hi
is there a red circle down in your task bar by the audio icon ( if you indeed have one in the task bar )
you could go to control panel then sound and audio and check in there that it is not disabled
and if you still have no audio you could click on this link which will hopefully take you to the gateway official website to download your audio driver use scroll down boxes to find your make and model
http://support.gateway.com/us/en/product/default.aspx?tab=1
good luck
hope this has helped you
Posted on Mar 31, 2011
  • Gateway Master
  • 32,281 Answers
Try installing the latest audio driver.
You can download the drivers for your model Gateway laptopfrom this WEB site. Make sure you select your model laptop and the correctWindows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
No audio device
The "No Audio Device Error" message is usually displayed by your computer when it does not detect any properly working audio device attached to it. You will not hear any sound from your computer when this message appears. Only the internal speaker of the computer can provide you bleeping sounds.
When this message appears on your screen, you will need to first check your computer's BIOS and ensure that the audio is set to "auto" mode. You should also check if you have installed the correct drivers needed by the audio device attached to your computer in order for it to work properly.
Audio Device Drivers The most frequent cause of this problem is an incorrect audio device driver that has been installed by the user. In order to double check if your driver matches your device, refer to the user's manual that came with it to look for its type and specifications. The audio device driver for an onboard device should be provided along with the chipset drivers in the CD that accompanies the motherboard.
Use the Device Manager You can use the device manager to ascertain if the audio device drivers are installed properly. To go to the device manager, right click on the My Computer icon, then click Properties, click on the Hardware tab and then Device Manager. If any device is marked with a yellow question mark, it is an indication that the required drivers are missing. It should be instantly clear if the audio device is truant.
Loose Connections on the Motherboard You can open your computer and directly look at the information written on the audio device itself. While doing this, make it a point to check all connections by ensuring that everything is properly plugged in its correct place. Sometimes, this error is also caused by loose connections and a sound card that has been improperly attached to the PC.
You can download the latest updated drivers from the manufacturer's website, either from your own computer or another. If you have used another computer, you can use a data storage device to bring the drivers to your machine and execute the software installer from there. Ensure that the driver you have downloaded is compatible with the operating system installed on your machine.
Is Your Audio Device Defective? If problems with your audio device still persist, you can opt to test the audio device on a different machine just to see if it's in good working condition. If it still doesn't work on a different machine, you have a defective audio device. You will need to get it replaced if it is under warranty or purchase a brand new one. Remember that you should buy the audio device that is compatible with your motherboard. In addition, don't forget to ask for the updated software drivers of the audio device
May 18, 2010 | Computers & Internet
No audio device driver for vista 54
Try to check the windows audio services in windows service, and make automatic, then try to check if not working then go to device manager and uninstall audio drivers and restart the computer and give some to to automatically install the driver then audi will work in case not working then refresh the driver from device manager and try to download and reinstall the windows audio driver then windows audio will work fine.
Mar 19, 2010 | Compaq Presario V2630US Notebook
"no audio device installed"
First check the device manager from the control panel. Check and see if there is a audio device detected and if it is a problem device.If the device has a problem try removing the audio software and then remove the audio device.then re-boot the computer and windows should detect the hardware and begin installing drivers. Make sure you have the updated drivers from Dell downloaded and the updated software. If it does not detect the hardware after re-boot you can try adding hardware manually in the control panel and have it auto detect any new hardware. If these thins do not work the audio card or built in audio may have stopped working. You can buy a basic PCI audio car for fairly cheap to install on your computer if you cannot get the audio to work.
Sep 05, 2009 | Dell Computers & Internet
No Audio
Here is the link to the page for the driver for your audio. once you install this you should be up and running again. Hope this helps!!
Jun 28, 2009 | Intel Computers & Internet
My speakers won't work we tried everything
do you have the audio drivers installed on your computer.go to control panel,sound,speech and audio devices and then click on sounds and audio devices.it should open up another window sound and audio devices properties.click on audio and check default audio device.should have some devices e.g realtekAC97.if its not there, google it to install and it should work.if this doesnt work please let me knoa.
May 30, 2009 | E-Machines eMachines T3830 PC Desktop
No audio devices installed
Do you have windows XP or Vista?
Do you have sigmatell audio card?
When this happens go to start->run type in services.msc and press run.
Find Windows audio service. Right click and select properties. SElect start type "automatic" and click on start.
Audio should work.
Please leave your feedback if issue was solved or if you still have that problem
May 28, 2009 | HP Pavilion DV6500T PC Notebook
Sound card not detected
ask to expert by calling 18002044427 toll-free number and get quick solution regarding your query...
May 31, 2017 | Computers & Internet
No audio device installed on my laptop
I'm not sure whether this is the exact same problem, as I was having, but mine just randomly quit while I was listening to music this morning. I got messages saying "No audio device installed", but when I went to device manager, all my audio devices said they were working properly. If this is the case with you, simply restart your computer. It may take a couple restarts, but this should work. My sound was back even before it finished shutting down.
If it helps anyone trying to get to the root of this problem, I am running XP on a Dell B130 laptop, with the following devices listed in Device Manager:
Audio Codecs
Legacy Audio Drivers
Legacy Video Capture Devices
Media Control Devices
SigmaTel High Definition Audio CODEC
Video Codecs
Hope this helps!
Jan 22, 2008 | Creative Labs Sound Blaster Audigy LS...
The yello esclamation mark signifys you need up dated drivers then it will go again.
Sep 14, 2007 | Ensoniq (6000708) Sound Card
Gateway M-7351u Notebook Logo
129 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
