Question about Quik-Lok Quik Lok QLX3 Keyboard Accessories
My new qlx-3 extension kit comes with a plastic bag with 2- aluminum collars and a couple of allen screws&wrench.What is this for?No,no instructions!
  • Quik-Lok Master
  • 5,603 Answers
The aluminum collars are PROBABLY safety stops to prevent the other clamps from slipping down too far if they work loose. I would expect they go on the vertical tubes aboove the X clamps.
Posted on Apr 01, 2011
What is the size of wrench for ovation guitar truss rod
If an Allen wrench, should be either 3/16" or 5 mm. Both were used.
Dec 09, 2016 | Ovation Music
My VOX ADVT50 is not putting out any sound
Firstly check all valves are glowing, if they all glowing, check speaker cone isn't blown
Jun 29, 2012 | VOX Amplification Vox Valvetronix VT50...
The wrench to adjust the Fender Jazzbass (Mexico) neck does not seem to be allen
it doesn't I think it is stripped if you have tried metric and S.A.E wrenches and nothing works this could be the case and it has stripped but try to look into the opening at the top of the nut with a flashlight if you can see the flats for an allen wrench then it might be still good but a weird size like 4.5mm ex. are you the original owner if not you could have a problem here but you might be able to get the nut out and put a new one in post back I want to check for the wrench size
Mar 27, 2012 | Fender& Standard J Bass Artic
Ground issues
Rule #1: All interconnected devices... amps, speakers, etc... SHALL be powered from a single receptacle OR power conditioning module.
Rule #2: All interconnecting audio cables SHALL be balanced, either XLR or TRS.
Rule #1 means running extension cord for power alongside a snake for instance.
Sep 06, 2011 | Allen & Heath Allen&Heath PA12-CP
Input jack fell inside
Yes, the jack MAY actually be broken. It will need to be serviced. Run cables through the handle to avoid plugs from being yanked sideways and breaking the jacks.
Aug 23, 2011 | Roland Cube-20x (20w 8" Modeling Guitar...
Behringer's Ultrabass BXL3000 - problem with the DI out, which I think it a loose wire. How do I get into it to find out?
You will PROBABLY find the 4 screws on the sides that screw into the chassis and then get frustrated that it will not come out... MANY of the Behringer things HIDE the other screws as the ones holding the handle... The trick is to get at them... The plastic end covers over the handle have ridges that snap under a metal plate that is over the handle. Carefully pry out the plastic near the handle to release these ridges... pry SIDEWAYS a bit... The ridges snap into small cutouts in the metal... what a pain these are. Use a small 1/4 inch screwdriver with blade vertical right where the handle comes out to bend the plastic outward... Dont reach in very far as the blade will catch the metal... just far enough to catch the plastic cover edge... it is scary. The two handle screws usually go into nut-plates that are a part of the amp chassis.
The DI consists of two sections of an op amp and is truly driven differentally. There usually is a couple of 120 ohm series resistors and a couple of hf bypass caps near the connectors
Feb 07, 2011 | Behringer Ultrabass Bxl3000
How to lower the action on a b.c.rich warlock bronze series
To fix the action on your B.C.Rich Warlock, you need an Allen Wrench, or Hex key. There is a truss rod cover on your B.C.Rich's headstock. Just open it using a screwdriver and you will find the truss rod. Then adjust the action using the hex key.
check out more here -
http://www.squidoo.com/b-c-rich-warlock-set-up-and-fixing
Nov 20, 2010 | B.C. Rich Dark Arts Warlock Electric...
I need to know how to adjust my truss bar on my washburn d10 to make the string action bigger
Actually you can do this by adding shims under the saddle to raise the action. Then use the truss rod to make the action uniform if necessary. I try to avoid making adjustments to the neck because it could lead to undesirable perminent alteration to the neck. If you do make adjustments to the truss rod you should tune the guitar to pitch and let it sit left alone overnight to allow the wood time to adjust to the new adjustments.
Here is a link to an article on Adjusting action on an Acoustic Guitar.
Jan 24, 2009 | Washburn D10sbc Acoustic Guitar
Quik-Lok Quik Lok QLX3 Keyboard Accessories Logo
47 people viewed this question
Top Quik-Lok Music Experts
Michial Gueffroy
Are you a Quik-Lok Music Expert? Answer questions, earn points and help others
