They probably mean starter rope. Disassembly would be required. Take pictures along the way to document the job in unfamiliar territory.They probably mean starter rope. Disassembly would be required. Take pictures along the way to document the job in unfamiliar territory.
You can't post conmments that contain an email address.
It is obviosly fuel starvation, have you actually replaced the fuel filter on the end of the hose in the tank? try richening the fuel mixture by unscrewing the H and L screw on the carb 1/4 turn on each, you may need a special tool to grip and turn these.
Lightly seat the screws all the way in....then back them out about 1 and 1/2 turns. From there here is how to do the final Zama diaghragm carburetor adjustments. http://www.zamacarb.com/tipspage.html
Oh, are you in for a job.
here we go,,,,pull air output tube. then remove bottom of air intake shroud...then remove impellar, then remove top half of air intake shorud... now all starting parts will be visable. They are mounted on top of the top half of the air intake shorud......careful, the fuel tank is mounted to the top half of the shroud...Good luck.
