Question about Honda Mmd 5000 Watt Generator W/ Engine Ngk 6000H
Can my eb5000 generator run an electric 7hp compressor
    Guru:
  • 479 Answers
7 horsepower is approx 5150 Watts so the compressor would be taking this power while running. On startup however the compressor can take a surge of upto 3 or 4 times this power so the generator wouldn't be able to supply this demand . In any case it's not advisable to run a compressor off a generator unless the generator is high powered, 20KVA or greater for 7hp.
Posted on Mar 31, 2011
Honda eb5000 generator starts fine seems to run good but idle control does not work . will not rev up at all.i can turn carb idle screw in to bring revs up it makes power out of the generator but idle
Like a lot of stationary engines a generator engine is governed, or at least should be governed.
That is to say, when the engine is started it should be running at a predetermined speed which is not an idle speed but the speed the engine works most efficiently and that typically would be in the region of perhaps 1800 to 2500 rpm. In the case of an alternating current (ac) generator the speed will be determined by the alternator and the requirement of the frequency of the ac output to be around 50 to 60 cycles per second.
It is the function of the governer to maintain that preset speed within fairly close limits so when an appliance is connected to the generator and switched on the load increases and if it were not for the governer the engine would slow down which would be unacceptable. The governer therefore opens the throttle and restores the speed to the preset value. When the extra load is removed the engine will speed up momentarily and then restabilise at the right speed.
The governer is somethimes an engine driven set of bob-weights hidden inside the crankcase and sometimes nothing more complicated than a flap moving against a spring in the blast of cooling air from the fan. In all cases the governer is connected to the carburettor, typically by an adjustable link that includes a spring.
From your description it would seem the governer of your generator engine is jammed, broken, seriously maladjusted or simply no longer connected.
I hope this helps.
Feb 04, 2015 | Honda Eb5000 Eb7000 5000 7000 Generator...
Honda eB5000 generator has no a.c. after sitting couple years . It does run but no power at output for tv.
You need to flash the rotor to rebuild the residual magentism so it can induce in the stator.
Sep 01, 2013 | Coleman Powermate Premium Plus 6250W...
I have a EB-5000 model B 50 Honda generator the high idle works but can't get it to idle down, I change the switch because it was broke, I looked all springs are there, when I put my finger on the governor rod and pull it back idles down, any suggestions
Apr 16, 2013 | Honda Eb5000 Eb7000 5000 7000 Generator...
Honda generator (eb5000) will not idle steadily
use premium non-ethanol fuel(shell,BPS etc).Many stations to the west & north (,Hustisford & many other town's PREMIUM are non-ethanol) and add some sea foam to it. that ethanol is junk. If not used in 30 days toss it. nothin' but trouble.
Jun 25, 2012 | Electrical Supplies
Generator dies when load is applied
I beleive,, edder: short, wire off alternater. or bad alternater
May 09, 2012 | Honda Eb5000 Eb7000 5000 7000 Generator...
My electricity provider is not reliable. I own 3 of your towers to heat individual rooms. I have settled on a generator to have when I lose power again. I want to run one of your towers, a light and a...
Each one of your heaters draws 1500 watts on HIGH & 900 watts on LOW. Obviously, your generator can not operate all three on HIGH. On low, all three would require 2700 watts of your generators power. Which leaves very little to operate any other electrical appliances in your home. Becasue these are electric ceramic heaters, there is no surge to them, when you turn tum ON. The wattage listed above, is continual wattage, when they are in use. There has to be an electrical motor involved to have start up surge (i.e Refrigerator, freezer, etc)
So, just operating what you described, will not use up all of your generator's power. You should have just under 1500 watts left over. Of course, if you used a battery operated radio, you could gain 25 additional watts of power.
I hope this helped you and thanks for choosing FixYa.
Sep 23, 2011 | Lasko 751320 Ceramic Heater
We are getting 155v on the 120 v receptacles
it may be running far to fast, just slow it down a little
how did you get this reading,,,on load or off load???
if off load hook up a light bulb and take another reading,,if its pulled the volts back down thats fine,,,if not plug in to the geny some thing thats close to its full load,,,"not more than this" now take the reading,,,
if still high lower the reves till its just 120v on full load
mind you,,,5000watts? thats a big un!!!!
Nov 19, 2009 | Honda Mmd 5000 Watt Generator W/ Engine...
CRAFTSMAN 7HP 2 STAGE 60GAL. STOPPED CREATING
take the air fiter on pump off and see when pump in running if it has suction if not could have debris under valve keeping it open
Mar 25, 2009 | Air Tools & Compressors
Honda Mmd 5000 Watt Generator W/  Engine Ngk 6000H Logo
166 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
