Question about Dishwashers
Hello i have a kenmore dishwasher 3380957 and the lock light is on i tried to unlock it and have a few times but nothing but lights flash.
SOURCE: Dishwasher Problem
According to my ultra wash dishwasher you have to hold the no heat dry button for 4 seconds and that is how you lock and unlock the control panel
Posted on Jul 17, 2008
SOURCE: Kenmore dishwasher Lock-On light flashing, will not start
my quickrinse light flashes and answers
Posted on Oct 29, 2008
  • 58 Answers
SOURCE: Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Posted on Jan 09, 2009
SOURCE: green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Posted on Feb 05, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Locked light is stuck on
Are you pushing the button repeatedly or pushing it once and and holding it on for 4-5 seconds? Just push and hold it on for a few seconds till the lock light goes off.
May 25, 2014 | Kenmore 16602 / 16604 / 16609 Built-in...
The lock on light is flashing and my dishwasher won't start any idea???
Hello, press and hold lock button until it stops flashing. Now should be unlocked.
Jan 17, 2011 | Kenmore Dishwashers
Kenmore Ultra Wash Dishwasher, model 665.15812, "locked" light stays on. Pressing and holding "no heat dry" does not cancel "locked" condition, neither does unplugging unit.
Hello Everyone,
Flashing Lock Button...tried pressing every button in every sort of sequence you can think of? Well try this!
After washing dishes by hand for a few weeks while I tried every solution I could find on the internet, I finally got my Kenmore 665.15812 Dishwasher to work! I found this post: http://www.applianceblog.com/mainforums/sears-kenmore/10277-kenmore-dishwasher-model-66515632000-flashing-air-dry.html
At the bottom Martee says that he jiggled the ribbon wire that is connected to the board (looks kind of like an IDE cable you'd find in a PC). I took off the inside pannel and the black box protecting the circuits. I jiggled the ribbon wire, and sure enough, I felt a click, shut the door, and everything was back to normal! HURRAY!
Dec 23, 2010 | Kenmore Dishwashers
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore Elite Dishwasher(665.15979990) wont drain
If the control panel is still lighting up I think it the thermal fuse has blown if you can take out the control panel and in that you will find the fuse you can test this with ohm test and here is a pic of what the fuse looks like and if you do replace this make sure you replace the new wires that come with the new fuse good luck hope this helps
Nov 21, 2009 | Dishwashers
"Lock on" light keeps flashing - cannot run dishwasher
same issue..
Other boards suggested heating element issue - but nothing very clear or compelte.
Aug 10, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dec 29, 2007 | Dishwashers
Dishwasher electronic panel locked
remove the touch panel and unplug it for couple of minutes. it should reset>
Aug 20, 2007 | Kenmore 15899 Built-in Dishwasher
Dishwashers Logo
392 people viewed this question
Top Dishwashers Experts
Owen Barnes
