Question about Randell 2010 Solid Door Commercial Refrigerator
How do you remove the door seal from a Randell 2010m rerfigerator and install a new one. The one that was shipped to me said snap in But I cant figure it out
    Scholar:
  • 83 Answers
Examine the NEW door seal, on the back of the seal, not the flat magnetic face you should see an arrow head shape. If this is correct then
FIRST READ ALL OF THIS
1. Switch off and unplug the fridge. Clean around the old seal with a toothbrush and hot soapy water, get right into where the old seal meets the door, inside and outside to remove all the old grime etc. This can hold the seal in quite tightly.
2. Gently pull at one of the corners, it helps if the seal is warm, eventually you should get a corner come free, then steadily work your way along the edge of the seal all the way round until it comes off.
3. Again get in there with the old toothbrush and hot soapy water and get the groove clean, it will make fitting the new seal easier.
4. This is the difficult bit (you are going to get sore thumbs) Steadily push one top corner of the arrowhead into the groove, if possible get someone else to hold it there, then push the next top corner into the groove, its really inportant to get the corners in first.
5. Work from one corner towards the other and stop at the middle.
6. Go to the other corner and again work towards the middle, try not to stretch the seal.
7. Repeat steps 4 to 6 for each ot the other 3 sides
8. Go back to the corners and with a flat wooden popsicle (lollipop) stick or similar (nothing sharp or you will wreck the seal) check from the outside that the arrowhead is completely seated.
9. Work all around the seal with your thumb pushing the seal firmly into the slot, then go gently around the outside and inside edges as in 8
10. Close the door, you may see that the seal is not completely flat but it will settle over the next day or so.#
11. Plug in and switch on the fridge.
12.Wash and dry your hands and open a beer, you earned it
Best of luck
Gordon
Posted on Apr 14, 2011
Water seals
doors or windows doors the seals go under trim that must be removed most just snap in place some use screws remove and replace weather strip . door seals they seat around the top in a grove on either side and inserts along the sides and bottom. door window seals out side remove door panel remove mirror pull up remove moulding inside just pull up strip and replace.
Jul 29, 2012 | 1996 Chevrolet Suburban
The gasket on the right hand French door is slightly torn, so I bought a replacement gasket. It's arrived, but I have no clue how to replace the gasket.
The gasket is easy to replace. Remove bins and shelves set them aside. Next at the top right hand corner remove the door trim cover pull it straight out and set it aside. Note the tabs on the inside of the trim are fragile. Peel back the gasket at the top forward edge and bottom frward edge and you will locate a hinge. Use a small screw driver to pop these hinges out. Pull out the gasket on that side first and the whole seal comes on out of there. The hinge slides out of the old seal. Just snap yer new back in. Do on door at a time. The trim pieces for each door are different. Snap your door trim back and check for propah opening and closing of door. Then party on!
LG french door service manual
Aug 13, 2011 | Refrigerators
Install door latch cable
Technical Instructions
See picture below
1. Remove door trim panel and water shield per
NOTE: Place a strip of masking tape along the edge of door before removing trim panel to prevent scratching the door with the trim panel removal tool.
2. Snap cable housing end from slot on inside door handle assembly and disconnect cable.
NOTE: Use care to prevent bending of cable housing retainer bracket.
3. Remove rear window channel retaining bolt to allow access to door latch.
4. Position a block (screwdriver handle) between the latch and the door inner panel and snap the cable housing end out of slot (towards inner panel) on door latch assembly and disconnect cable at latch.
NOTE: Use care when removing cable housing to avoid bending of the latch. Discard cable.
5. Hook up new cable at latch and snap cable housing end into slot.
NOTE: Make sure the cable housing is fully seated in the slot.
6. Apply a light film of Teflon grease to the barrel end of the cable. See Figure A.
7. Install return spring. See Figure A.
NOTE: Ensure that the push button rod is located between the spring and the door inner panel.
8. Install foam block at latch. See Figure A.
9. Position water shield over the return spring and install push pin to retain upper portion of water shield. See Figure B.
NOTE: Push pin goes in the same hole as the return spring.
10. Clean hands of grease before performing step 11.
11. Remove protective backing along the lower edges only of the water shield. See Figure A.
12. Install latch water shield at door latch. Pinch the exposed adhesive surfaces together to secure the water shield. Check to insure water shield is not showing through the door shut-face latch access hole. See Figure B.
13. Attach cable to inside door handle assembly and snap cable housing into slot.
NOTE: Make sure the cable housing is fully seated.
14. Check the gap as shown in remote control using a 3/16 drill bit shank end. The drill bit shank should fit in the gap without any clearance and a tight fit is preferred. See Figure C.
15. If the drill bit is too loose or does not fit, adjust by bending the cable bracket as required.
16. Place plastic wedge on remote bracket as shown. Wedge must fit with at least a light press fit for retention. See Figure D.
17. After installation, Apply a dab of special Teflon grease, supplied with the service cable to cable housing openings at inside handle end. The grease should surround and contact the cable all the way around, to seal the opening between the cable and the cable housing.
18. Check all latch functions to insure correct assembly of latch system. If the inside handle does not release properly, replace the inside handle remote release mechanism.
19. Reposition and install trim panel using new push pins if required.
Dec 07, 2010 | 1993 Ford F250
I need to change the door seal on a 1990 ge fridge and top freezer, looking for tips on how to remove and replace seal. i have the new seal.
place new seal in warm water for 15 min. start at one corner, remove appr 4 srcews in each direction pull old gasket down. now start to install new. continue to remove old and install new. make sure to remove weight from door. after your done place a film of vasoline on mating surface.i sometimes will roll a small amount of paper towel to insert where gasket is not wanting to pull up . push door firmly shut for a few days.
Jan 19, 2010 | GE GTS18HCM Top Freezer Refrigerator
My Daewoo FR370 DLX two door rerfigerator sweats in the outside edge of the door. Has the door seal got worn off. It is five years since I bought this refrigerator. Kindly assist me
yes, the sweating is from the temp difference from the inside and outside of the door. The air must be escaping past the seal.
Nov 25, 2009 | Refrigerators
Inside door handle doesn't work (removing the driver side panel)
If you have power windows start by disconnecting your negative battery cable. Then you need to locate and remove the screws that hold your door handles in place (they may be hidden by snap in, or snap on clips). Once you remove the screws that hold the door handles, remove any wire connectors to the handles, if they're not power you will need a small hook (kinda like a knitting needle) to remove the window crank. A manual window crank is held in place by a clip on the base. Slide the hook behind the base and remove the clip. The door panel itself, is held on by snap in clips, and you will need a small pry bar to pull them from the door (try to gat as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are removed from the door, pull the panel upward to remove it from the door.
Install in reverse.
I hope this helps you, and I wish you luck on your repair.
May 04, 2009 | 1992 Chrysler New Yorker
Cant find driver door windows 1996 jeep cherokee 2 door in Chile
I checked shipping cost and its around $700.00 !! I could buy a whole car for that much!!! I see why you are having a problem. Good luck with making something!
Mar 17, 2009 | 1996 Jeep Cherokee Sport
Dishwasher is leaking on the floor during wash cycle
If this is a new dishwasher, then I suggest you call in a warranty issue on this one.
Nov 26, 2007 | Kenmore 24 in. 16259 / 16254 / 16252...
Randell 2010 Solid Door Commercial Refrigerator Logo
95 people viewed this question
Top Randell Refrigerators Experts
Dennis Boxerman
Jude24
Are you a Randell Refrigerator Expert? Answer questions, earn points and help others
