Question about Panasonic CQ-C8100U CD Player
Scooter stereo ok the make of the battery is a nautilus xhd-m-24 the make of the deck is a panasonic cq-c8303u i currently have 2 speakers hooked up the other 2 are just bare wires the speakers are new yes the sub is bridged as far as i can see there is no shorted wires and no i dont have a continuity tester at this time i do have a greenlee gt-11 voltage detector if that helps
    Brigadier General:
  • 6,966 Answers
Hi again,
My apologies, missed the connection. Now I remember, must be really getting old.
Back to your concern, which fuse pls? the 15 amps for the Panasonic or the amp"s fuse.
Incidentally, even if the speaker wires were wired incorrectly, that would not cause the fuse to blow. The only way the fuse would blow is if the unit was connected with the polarity reversed, even just once. Internally, most units have a reverse protection diode and/or regulator that would short circuit itself. Thereafter even if it were wired correctly to the battery, the fuse will always blow.
Looking forward to hearing from you.
Posted on Aug 05, 2008
Can this be hooked up to cell phone???????
Yes it does as long as your phone supports bluetooth. Here's a link to the manual. You can download it for free. http://service.us.panasonic.com/OPERMANPDF/CQC8403U.PDF
Jan 12, 2011 | Panasonic CQ-C8303U CD Player
I took my panasonic cq-c8303u out of my jeep and put it in my civic hooked all the wires up right but no power to my deck whats could the problem be?
Check the in line cylinder fuse for the radio, cause they blow easy. Also, check the radio fuse under the dash or wherever your fuse box is located. Make sure you solder the connections for a good contact, cause just wrapping electrical tape around the wires will cause you problems down the road when you go over bumps.
Nov 11, 2010 | Panasonic CQ-C8303U CD Player
Panasonic cq-c8303u wiring diagram
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
Panasonic CQ-C8303U. Hooked up an amplifier and it works with the radio but when i put in a cd the amp doesn't work. the receiver just plays with normal sound.
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
What antenna do i use for a DP351x?
You run the factory antenna that you have hooked up to your current deck.
May 14, 2009 | Panasonic CQ-DVR909U Car DVD Player
Volume won't turn upon my panasonic cq-vad7200u car stereo
this may be a pre amp only deck
and if it is ou have to buy amplifiers to make the speakers work
May 07, 2009 | Panasonic CQ-VAD7200U Car DVD Player
Scooter stereo
As long as the battery is 12volts then it should be ok. Since you have verified that the yellow and red are wired to the positive terminal and the black is to ground, fuse blowing would indicate that there is an internal short in the unit. You need to open it up and follow the yellow wire where it leads to and check the surrounding components.
Does the fuse blow when just connected or when powering it up?
Aug 05, 2008 | Panasonic CQ-C8100U CD Player
Panasonic cq-c8303u Car stereo problem
There is for sure a hook up problem my friend. There should be a memory wire that always has power to it even when the car or the ignition is off. Then there is a switched type wire that only comes on when the cars ignition is on. Check both of these wires in the car. Check the car wiring diagram to confirm this. To confirm the wiring in this vehicle, I Good Luck with this install. And if all else fails, don't take a chance and blow out the unit, take it to a pro to be installed. Good Luck found the right wiring diagram for your car. Confirm this wiring diagram with this one you have. Go here:http://www.the12volt.com/installbay/stereodetail/955.html
Jun 19, 2007 | Panasonic CQ-C8303U CD Player
Panasonic CQ-C8100U CD Player Logo
143 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
