Question about Vacuums
I have a hoover elite cyclonic cansiter vacuum the vacuum works fine but I can not get power to the power nozzle
    Sergeant:
  • 192 Answers
If there is no suction in the hose it is clogged.
Remove the hose at the bottom and clear and obstructions out.
If this does not fix the issue please leave a comment and I will assist you further.
Thanks
Posted on Mar 31, 2011
How to open Hoover S3825
Hi there! We recommend taking your cleaner in to a Hoover authorized service center to have the motor replaced or repaired. I have included a link to the service center locator if needed. Hope this helps!
Service Center Locator
Oct 05, 2014 | Hoover Elite Cyclonic Canister Vacuum with...
Troubleshooting hoover
Hi! Here are some basic trouble shooting steps for the Presto 2-in-1.
1. Remove the dirt cup. Push the release catch on the hand vac and pull the dust container off the motor unit
2. Remove dust container from filter assembly and cyclone separator.
3. Hold the dust container over trash can and tap out debris.
4. Check cyclone separator for additional debris, empty into trash can
5.Check the rinsable filter. If rinsing is needed, remove rinsable filter, rinse with pleated side facing up. Allow filter to completely dry for at least 24 hours.
6. Remove any hair and debris from the brush roll.
7. Remove the floor nozzle from the cleaner by pressing the nozzle release button on the back of the floor nozzle and pulling from cleaner.
8. Check and clear nozzle of any obstructions.
Hope this helps!
Aug 06, 2014 | Hoover Vacuums
I cant get my hoover vaccum brush to spin
First be sure the switch/circuit breaker on top of the nozzle is on. The brush also will not turn unless the handle is released and tilted back. This model of Hoover has a gear drive to turn the brushes. This was VERY prone to problems, and Hoover discontinued making replacement parts for it several years ago.
Mar 18, 2011 | Hoover U8147-900 WindTunnel V2 Bagless...
Vaccum seems to cut off after short use like its hot,,once it cools off i can use again
Check filter. Clean if needed. The filter should be cleaned when it appears dirty. Simply remove filter, rinse thoroughly under warm running water until clear, then allow to thoroughly air dry. The drying is very important. Additional filter cleaning instructions are on page 13 of the manual.
Check the pleated exhaust (HEPA) filter. If dirty, cleaning is necessary. Instructions for removal and cleaning are on page 14 of the manual.
Check hose, wands, and power nozzle for blockages.
Hose: detach at both ends. The ends of the hose are the most common areas for a blockage. Check visually and clear as much as possible if present. If not visible, hold one end up and drop a coin in. Lift the end until the coin falls through. If it doesn't, there's a clog.
The easiest way to unclog a hose is to use an air pressure hose, or a canister vacuum that has an exhaust blower that the hose can be held too. If enough pressure, it will blow the dirt out. Make sure to put a plastic bag around the loose end to hold the dirt.
Visually check wands and power nozzle. The bend in the power nozzle connection is another common place for clogs. A wooden spoon handle, or similar blunt object, can be used to push the debris back toward the brush to clear a blockage here.
If none of these are the problem, contact a vacuum service center, preferably Hoover, for assistance.
Manual:
http://www.hoover.com/pdfs/manuals/S3865.pdf
Thank you for providing the brand and model info. It helps a lot.
Mar 05, 2011 | Hoover Platinum Cyclonic Bagless Canister...
When I stop the hoover it seems to deposit dust on the carpet. How can I stop this from happening?
It sounds like the vacuum is clogged, probably the hose. You'll need to remove the hose from the vacuum and use a vacuum with a blower, or an air pressure gun, to clear it. Do so from the tank side of the hose. You can also try placing the nozzle end of the hose to the tank and turning it on. This reverses the flow through the hose and may be enough to clear it.
Also, check the power nozzle where the hose attaches to it. There may be a clog there.
Nov 13, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover Savvy Bagless; wind nozzle doesn't turn
has it been taken apart before? if so it wasn't put back together right.call me and i will walk you through putting it back together so it will work.i don't charge for the help just like to help people
Aug 15, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover elite rewind with widepath
Check the hose and the dirt inlet for a blockage.
May 27, 2008 | Hoover U8147-900 WindTunnel V2 Bagless...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
