Question about IBM ThinkPad T43 Notebook
IBM T43. Works perfectly on external monitor. At startup the laptop screen shows hundreds of multicoloured vertical lines which are evenly distribited across the screen. After a few minutes the pattern changes to a predominant blue green screen with a few dark vertical lines each a few millimetres across.
  • 81 Answers
Connection between the screen and the motherboard is not correct, maybe ribbon cable have interruptions. The video card is good.
Posted on Mar 31, 2011
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Jul 29, 2012 | Acer Aspire Computers & Internet
My IBM R52 laptop displays some vertical thin lines (red,green,blue,white,etc). I noticed this problem arises basically IBM R52 and R80 models. Some of my friends too are suffering from this problem and...
This sounds similar to a fault i had with an old dell laptop... very thin vertical lines running the length of the screen. Unfortunately it was an LCD problem, the screen was kaput replacing the screen solved the problem.
To test if it is an LCD fault, simply plug your laptop into an external monitor... if you get no lines on external monitor then its a faulty LCD screen.
Is that solution genuine enough for you?
Aug 27, 2010 | IBM ThinkPad R52 Notebook
I have a hpdv6000 series laptop and recently it
Hi:
I believe that your LCD panel is the problem, but you should verify that you have good video, by toggling to an external monitor to check your output. If it dispays good, you have an LCD problem.
Nov 10, 2009 | HP Computers & Internet
Vertical lines on lcd how can i fix it works perfect with ext monitor and i did bios update and it help some?
Restart the Computer and access the BIOS and check if the vertical lines are visible. If the vertical lines are visible in the BIOS then the issue is with the LCD screen itself and may require service. This is confirmed when an external monitor works fine. If the issue is related to the video card of the Computer then the lines should also appear on the external monitor which is not the case.
Oct 24, 2009 | Dell Latitude C600 Lcd LCD Display
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
Vertical lines on thinkpad T43p screen.
You have identified the fault is the video card, I am in agreement. The fault is on the motherboard and a replacement motherboard is the only fix. This may not be a cost effective solution, I would recommend you put your money towards a new laptop.
Jun 27, 2009 | IBM ThinkPad T43 Notebook
Ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Jun 13, 2009 | IBM ThinkPad T43 Notebook
Double display with my IBM think pad T43
have you tried Function F7/F8 ?
Make sure that your display driver is installed correctly.
I had the same Laptop as you did and was able to have dual monitor.
Also check your Display driver in your control panel and make sure it set to dual monitor.
May 12, 2008 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
225 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
