Question about Toshiba Televison & Video
I have a 52HMX84 DLP projection Television. The LED indication is... Green blinks at 0.3 second intervals - red light solid. Manual indicates the lamp is not working correctly so I ordered a new one and replaced it. The exact same result. In the past, the bulbs popped and it was obvious the bulb was used up but in this case both the current bulb and new one look fine. What could it be and is it worth fixing?
  • norm_paulsen Apr 04, 2011
    I have checked the solution provided as far as I can go. Its quite difficult to get to the board without a lot of screws removed and wires having to be adjusted. I can see and feel two capacitors but they appear flat on the top but I can't get to them easily to really check. They are about 2-3 inches high and about 1-2 inches in diameter. So I'm still working on it.
  • Toshiba Master
  • 6,993 Answers
I think this time, your TV is having a power problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 31, 2011
Toshiba 62 inch dlp tv keeps flashing green and will not turn on
green flashing for .3 sec with solid red indicates lamp problem. and do you have the manual? If so, look in the appendix for a section 'LED indications'. that gives you the code for the indications.
Good luck..
Aug 29, 2011 | Toshiba 62HM195 62" HDTV
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
Lamp went out & replaced it but no picture. Sound comes on!!!
you have a safty switch open most likely on the door you took off to replace lamp
Feb 03, 2010 | Toshiba 62HM95 62" DLP HDTV
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Had blue screen, now no picture and red light
Press the menu and the device/input buttond on the det both in together and hold in for 5 seconds to see if the led will blink a two digit code such as 3 blinks slight pause then 4 blinks. I would almost bet that you have a 34 code come up. But respond to this same post and let me know which two digit blink code came up, and I will assist you with whats wrong with your DLP.
Aug 08, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 52hm84 Led Indication Green light Blinks @ 3 sec intervals during solid red light I have replaced with 2 new bulbs from Tosiba within a week and still have the same condition (saying the lamp...
the ballast or the DMD are the only other two possiblities. you will need to trouble shoot if you would like a link to the service manual let me know, they email it right after purchase and offer free tech support.
Apr 26, 2008 | Televison & Video
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Televison & Video Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
