Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Brush spin indicator does not spin when turned on. model F5915-900
2 Suggested Answers
Dissolu
  • 221 Answers
SOURCE: Hoover Steam Vac with Clean Surge model #F50905-900
All you need for your item is the belt.dissassemble the unit and you will se the track where the belt was, or even the old ne snapped an trapped somewhere inside. brush assembly purchase will not solve this.
update me about your progress.
Good luck
Posted on Jun 24, 2009
Change brush indicator light
If the light is not glowing it means the brush roll is not spinning. The belt may be stretched and need replaced. The brush roll may be installed improperly. The magnet in the brush roll has to be aligned with the indicator light for the light to work when. The brush roll is spinning
Mar 30, 2014 | Kirby G4 Bagged Upright Vacuum
Just purchased a reconditioned model. Makes a ton of noise and the bottom brush doesn't seem to turn like in my old Oreck. Does that indicate it needs a new belt?
Your Dyson does have a belt but its one that cant be replaced it is called a clutch assy. if your roller brush isnt spinning then it could be that you dont have the purple knob on the left hand side if your facing the vacuum to the carpet setting. if you do have it on the carpet setting and its still not spinning then your clutch need to be replaced.
dyson roller brushes donot rotate as fast as Oreck roller brushes. in fact they are rotate at about half the speed. so keep that in mind.
Apr 17, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
My brushes on my Hoover Steam Vac stopped spinning again! I took the brushes out and they turn fine, but when inserted back into the base, they do not turn, AGAIN! Anyone know what the problem is and...
Tip is slightly, do the brushes spin then? If so, then the brushes are air driven. By the spin indicator at the front of the machine, you'll see a small screen (same type of thing as is in your dryer), scrape it, you'll probably find there's a build-up of fluff. Clean off the fluff, and try again.
Nov 01, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Scrub brushes not rotating
Hi There,
You'll need to first diagnosis why these brushes are not spinning. When the SpinScrub brushes on a Hoover SteamVac don't spin, this can be 1 of 3 different things.
In order to diagnosis which one of the problems is causing your problem, here's what you'll need to do.
Step 1. The first and easiest thing you should check is to make sure that that the brush speeed selector knob on the top of the machine is turned on, and is not in the off position. This may sound obvious, but I've had several cutsomers that have come in with this exact problem, only for the brushes to be turned off. Also make sure that the SteamVac's handle is reclined, and not in the upright position. There's a switch inside that shuts the brushes off when the SteamVac is moved into the upright position. If the brushes still are not spinning, move on to step 2.
Step 2. You'll need to remove the SpinScrub brushes from the SteamVac. Turn the machine upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed (my left hand was holding the camera, lol), but the tabs on the left hand side are in the exact same location:
Step 3. Once the brushes have been removed, plug the machine in, make sure that the handle is reclined. Look in the SteamVac where the brushes used to be. You should see a hole that is square shaped where the brushes go into.
Turn the machine on, and look to see if this square shaped hole is spinning. If the hole is spinning, this indicates that either the brush block itself is bad, or there maybe something clogged (such as pet hair) in the brushes that's preventing them from spinning. If the square hole is not spinning, this indicates that your internal turbine brush gear has gone bad. Here's a link to a repair that I've written on how to replace the internal brush turbine gear if the square shaped, female receptacle hole is not spinning.
If the square shaped hole is spinning, here's what you may do to see if the brush block is just jammed up with debris, or if the brush block itself is bad and needs to be replaced:
Step 1. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem.
you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken. If the pole has broken, you will simply need to replace the brush block.
It can really only be one of these three things that are causing your brushes not turn. Here are links to all of the products that possibly need to purchased (if the brushes weren't just clogged) on our website for the model that you listed this repair under, the Hoover F7425-900.
- Hoover Brush Turbine Gear Assembly Part 43191009
- Hoover Brush Block SpinScrub 6 Brushes For F7425-900, Part #
48437030
I hope that this helped you figure out the problem. If you have any follow up questions, please use the Clarification Request form here on Fixya and I'll be more then happy to follow up with you and help you out. If you found this helpful, may you kindly please rate my repair helpful by clicking the thumbs up icons in the top right hand corner of the repair? This is really what keeps Fixya repair experts coming back to give free repair advice, and helps Fixya users continue to get the free replies without having to pay for answers. It's greatly appreciated.
Thanks,
Chris J.
GoVacuum.com
Apr 13, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Bottom wheel won't turn and belt is on
When a Dyson DC07 roller brush does not spin, it can only be caused by one of two problems.
The Dyson DC07 uprights use a clutch mechanism to control the brush spinning when you change the floor / carpet switch. When the brush doesn't spin, it's caused either by the clutch or roller brush gone bad. Most other uprights use a belt to spin the roller brush, and if something is stuck in the roller brush it will cause the belt to break. Dyson vacuums however will make that awful grinding noise rather then breaking the belt.
I'll be happy to walk you through step by step on how to diagnosis this problem and find out which one of these two parts is bad on your vacuum.
Step 1. Make sure the vacuum is unplugged. Then turn the vacuum upside down so that the brushes are facing up. It's easiest if you put the head of the vacuum on top of a bench, or counter top. This is how the vacuum should look:
Step 2. You see on the bottom of the vacuum 3 plastic screws that are usually the same color as the vacuum cleaner. If you're vacuum is purple, the screws will also be purple. Use a flat head screwdriver, and turn each of the 3 screws a half of a turn, counter clockwise to loosen then. After each screw has been turned (you don't need to remove the completely, just a half of a turn is all), simply pull upwards on the bottom plate to remove it.
Step 3. You should now be able to see the roller brush exposed. You'll now need to remove the roller brush. This will take some patience, and some work in order to get this brush out of the vacuum. There is a special tool that has been designed to help you get the brush out easier. I would try getting the brush out first before buying this special tool. The easiest way is to use a flat head screw driver and pry the belt up while pulling up and out on the brush. With some patience and some maneuvering, you'll be able to get the brush out of the vacuum. Here's where you should put the flat head screw driver on the brush:
Step 4. Once you get the brush out of the vacuum cleaner, it's time to test it. Use your finger tips to hold just the end caps on the very end of the roller brush. While holding just the end caps, use your thumbs to try and spin the roller brush. Does the brush spin freely? It should rotate completely several times on each spin. If the brush doesn't spin, or you feel some kind of resistance to the brush spinning, then this indicates that your roller brush has gone bad. Here's a picture of how to test the brush:
If the roller brush went bad, then you'll need to purchase a new one. Here's a direct link to the roller brush your machine uses on our website GoVacuum.com:
http://www.govacuum.com/dysondc07.html
If the brush however was able to spin freely, and it spun multiple times on each spin, this indicates a little more serious problem of the clutch itself has gone bad. The clutch replacement repair is a much longer, more challenging repair to do. There is a very helpful video on how to replace the clutch below so that you may follow step by step instructions on how to change it. It was really helpful for me the first time I did this repair.
If you need to replace the clutch, here's a direct link to the clutch your Dyson DC07 uses on our website:
http://www.govacuum.com/dydcclasfore.html
Here's the video on how to replace the clutch:
When the brush stops spinning it can only be one of these two problems. This clutch mechanism was so problematic that Dyson removed it on the second series of the DC07 models. I hope that this repair was helpful in diagnosing your problem. If you have any questions about the diagnosing, or the clutch change, please feel free to use the Clarification Request form here on the Fixya repair page. If this was helpful you, please be sure to rate my repair as helpful by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
Apr 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brushes won't turn on my hoover steam vac dual v
Hi There,
Unfortunately the answer above is far from helpful. The filter has absolutely nothing to do with your brushes not spinning, and you can really replace the turbine yourself without having to take it into a shop to fix it. Here's a much more helpful diagnosing of how to check the brushes, and fix the turbine if needed.
There can be serveral things that may have gone wrong with your Hoover so that the brushes stop spinning. Unlike the other "expert" above I will walk you through step by step on how to diagnosis this problem, and fix it. Unfortunately there is no belt or band on this model, but instead it's actually a turbine assembly that drives this brush.
Possible Problem #1. Usually the most common problem when the brushes stop spinning is that the brushes have simply gotten clogged with something that is preventing them from spinning. Especially if you have pets in the home, this is a common problem. Here's how you can clean these brushes.
First, turn the machine upside down so that the brushes are facing upwards. Pull down on the upwards on the brushes and they will easily snap right out of the mahcine completely. . Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. It's important to make sure that the brush switch on the top of the machine is turned to "Rotating Brush Speed Hi", and that the handle of the machine is reclined down. There is an internal switch inside the machine that turns the brushes off when the machine is in the upright position, so you'll need to step on the handle release pedal to ensure that this switch is engaged. Hopefully the brushes just needed to be cleaned, and they will now work now that you have reinserted them. If this still didn't fix your problem, move on to the next possible problem.
Possible problem #2: If the cleaning didn't fix your problem, remove the brushes from the machine again. Once the brushes have been removed, the handle reclined, and the brush switch turned to fast, turn the machine on. Where the brushes were sitting you'll see a square shaped hole (pictured below) that the brush stem fits into that actually spins the brushes. This part should be spinning while the machine is on. Here's a picture of that part:
If this part is not spinning, then your Turbine Gear Assembly has gone bad and needs to be replaced. If this part spins however, then this indicates that your brush block is gone bad, and needs to be replaced.
Here are links to the exact parts for your model that may need to be replaced:
Brush Block:
http://www.govacuum.com/hov2st6blpa4.html
Turbine Gear Assembly:
http://www.govacuum.com/hostretubrge.html
Here's also a link to a Fixya repair solution that I've done explaining step by step how to replace the turbine gear:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
I hope this helped you, please be sure to rate the repair or leave feedback if you found this repair to be helpful.
Thanks so much,
Chris Jones
GoVacuum.com
Jan 12, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
The brushes will not turn but the shampooer will come on
1) check the filter by the spin indicator (the plastic cover snaps off). Clean if necessary. See if this solves your problem.
2) take out the spin brush assembly (pull out, there may be tabs you need to push to get it all the way out. Clean out dirt and hair. This may be all you need to do, if not take step 3
3) turn on the machine with the brush assembly out. Do you see where the square shaft the drives the brushes goes in? If the socket does not spin, you probably have a seized up turbine assembly.
4) remove the top that covers the motor/turbine (you probably have to take out some screws) The turbine assembly is towards the front. Remove this (again, a couple of screws) and turn it over--there will be some gears. If you can get these gears turning smoothly together you should get the turbine working again. I used a pair of pliers to turn the metal shaft.
Put everything back together and try it out!
Nov 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Good luck
Jun 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Riccar model rad.7 upright (radiance). roller brush won't turn and red roller brush indicator is on. roller will turn easily by hand and belt is in place. how do i fix this?
As you already know, the red brush indicator light indicates that the brush roll has stopped turning, usually because an object has become stuck in the brush roll. When that happens you should turn the machine off (unplug it also for safety), remove the obstruction and turn the vac back on. That should have cleared the light and allowed your brush to turn again.
Occasionally, you will get debris in the brush roll end caps and the brush roll will spin slower making the sensor think there is an obstruction. You can remove the brush roll, pop the end caps off and clean out any debris to see if that helps.
If none of the above worked it is possible that the brush roll sensor is bad or the circuit board in the machine is bad. You'll need a Riccar service center for that. The good news is your Radiance has a 6 year warranty.
Feb 22, 2009 | Riccar 8955 Upright Vacuum
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
