Question about Acer P1165 DLP Projector
The Acer projector P1165 displays white vertical lines, how can i solve this?
My acer projector show the verticals lines on top
Posted on Aug 04, 2012
SOURCE: White vertical line on left side of screen
omg, I just figured out why OUR projector was doing this! There was an adaptor plugged into it that we use to hook it up to cable to watch games/tv shows sometimes...once I unplugged that from the projector the lines dissapeared!
Posted on Oct 02, 2008
  • 8 Answers
SOURCE: Vertical lines on projected image from a Dell Data Projector. White vertical lines are appearing at even spacing across the width of the image projected. At a loss to how to fix this. Any ideas as to
that is due to lcd filter units , try to align, precision work
Posted on May 25, 2009
Marrie
  • 563 Answers
SOURCE: My projector has vertical lines on display;
Hi there
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
Posted on Apr 10, 2008
projdoc
  • 2237 Answers
SOURCE: White Vertical Lines on screen from a JVC projector
bad pcb. get your money back.
Posted on Aug 07, 2009
projdoc
  • 2237 Answers
SOURCE: dell 5100mp dlp projector - white vertical lines evenly spaced
clock and phase are off. go into menu and reset the settings to factory default.
Posted on Sep 02, 2009
There is a white vertical lines appearing every time we open Acer X1130P DLP Projector
means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD120
Nov 20, 2013 | Acer X1130P 3D Ready DLP Projector...
Does anyone know the part number for DMD chip in Acer X1260 projector?
Hello i got issue with white and black dots on ACER X1260.
The orignal parts was a 1079-6319W...
I tryed to put on a 1079-6329W supposed to be compatible.
I got white vertical lines on screen and no more pixel dead, this reference seems not compatible ( i think its 18W->19W ; 28W ->29W only).
I tryed to clean up with KF special contact F2, chip pins, socket, cards connectors, but nothing worked, still vertical white lines with 1079-6329W chip ( instead of 1079-6319W).
I hope this can help everyone in trouble with Acer X1260 and other.
DMD chips are not so compatible !!!
Sep 07, 2013 | Acer X1261 DLP PROJ SXGA 37001 Multimedia...
What causes white vertical lines on dlp projector?
Possible fault on the mother board as there are noise on the LCD display. You might need help to sort this out if the fault does not clear even after the lamp works for some times.
Nov 05, 2011 | InFocus ScreenPlay 5700 Multimedia...
I plugged in the acer dlp and it came out a white vertical lines in the display,is it at the bulb? or is it in the settings?
this sounds like the DMD board on the light engine not working properly. It's not something that can be fixed in the settings, but it is a hardware failure. light engines are usually very costly to repair. if the projector is still under warranty have it serviced by Acer.
May 27, 2011 | Acer X1130P 3D Ready DLP Projector...
Vertical line white, regular, blinking.
I don't think it's the bulb. Sounds like an LCD panel issue. Maybe one or more of the 3 LCD panels is either not working right or the unit has been dropped/jarred and the panels have moved (All three have to line up right optically to give the right colours). You need to take the projector to a qualified service centre.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Apr 01, 2009 | Acer Projector Lamp for PD110, PD110z
Ep716 has vertical line
IF THERE IS WHITE VERTICAL LINES IN YOUR PROJECTION THEN REMOVE THE MOTHER BOARD AND REFIT THE BOARD OR U CAN JUST PRESS IT FROM UPPERSIDE THE PROBLEM WILL SOLVE OUT
CHINTAN.A.SHAH
INDIA
Jul 23, 2008 | Optoma EP716 Multimedia Projector
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
Acer P1165 DLP Projector Logo
1,542 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
