Question about Panasonic Lumix DMC-FZ7 Digital Camera
My flash won't go on!
Hi! I release the flash as usual but it won't go off!
  • Coco10019 Aug 13, 2008
    I just sent to to Panasonic for $161.  Address is on their website and they are reliable.
  • Anonymous Sep 21, 2008
    My flash won't work either.
Me Too! Maybe the camera is badly made
Does the camera have a separate battery for the flash or is it just the main one?
Posted on Nov 09, 2008
#1. Make sure that the flash head has popped-up fully.
#2. What is the mode dial on your FZ7 set to? In "movie" mode and certain scene modes the flash is fixed to OFF, even though you may open the flash.
#3. Also, check to see if the battery is charged.
If none of the above work, then it is likely that the flash has expired. Send the camera to a service center to get it repaired, or just buy a new one.
Posted on Sep 14, 2008
I have this problem also, any answers?
Posted on Aug 13, 2008
2002 audi a4 e-brake won't release
It sounds like your rear brake pads are frozen to the rotor, or a small amount of rust is causing them to stick. Put all the tires back on and try to drive a few feet, that usually pops the pads off the rotors.
Dec 26, 2012 | 2002 Audi A4
Clutch won't release
Hi Anonymous, and the usual suspects are:
1. Clutch controls improperly adjusted.
2. Lubricant level too high in primary chaincase.
3. Primary chain badly misaligned.
4. Clutch discs warpped or rust bound.
5. Insufficient clutch spring tension.
Good luck and have nice day.
Aug 06, 2012 | Harley Davidson XLH Sportster 883...
Err 05 message
Impact damage to flash or spillage (usually something sticky like Coke) around the pivots (the two places at the back on either side that the flash attaches to the top cover). Sometimes a small amount of water will cause the screw on the release side of the flash that it pivots on to rust, causing the flash to freeze. Need to take it apart and clean (I use Windex) and lube (grease, not oil!) the pivots. Scrape the rust off the screw with an Xacto knife and then cover with grease so it won't rust again. Just did one with this symptom today
Apr 05, 2012 | Canon Rebel XT / EOS 350D Digital Camera
My canon mp160 printer has the color light blinking (I checked to make sure it has ink and the cartridge is in correctly) and won't print color. Thanks for any help.
Usually the cartridge is out of ink in which case get it refilled or it may be electrically failed in which case you will need to buy another cartridge.
If putting a refilled cartridge in the machine you will normally get some kind of error code, to clear this, press and hold the resume button (Black with red circle with an arrow head pointing towards you) for about 10 seconds then release it and usually you can print. The orange light will however stay illuminated or flashing.
Sep 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Check the dash once you turn the key to the run position the passlock runs a security check using a set resistance value through the chip in the key. If the security light begins to flash the reading it received was incorrect or it didn't get a reading at all. You can try reseting the value it is looking for by turning the key to start then releasing it. After 10 minutes turn it off then cycle it start again leaving it in on for 10 minutes then back to off then one more time. After the third cycle has completed for a total of 30 minutes. You should be able to turn the key on and start the vehicle. If the light continues to flash their is a problem with the chip in the key or the connections within the ignition its self. Both are common but a Pass Lock Relearn as described above will usually adapt to the poor connection values. Hope this helps.
Aug 28, 2011 | 1999 Chevrolet Lumina
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
When I am using the flash in any mode other than auto, there is a 1 second delay after I hit the shutter release button. Why?
this delay happens due to your Flash adjustment.You may have changed it to "SLOW FLASH" accidentally..
go to MENU and find 'Flash set up' sub menu and than cancel 'Slow Flash ' mode..
than you flash will fire again as usual , normal mode..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Jul 19, 2011 | Nikon D50 Digital Camera
Why must I wait 4 or 5 seconds before taking a second photo when using the flash?
Thats usually the case when the flash needs to charge before taking the next picture.
Jun 27, 2011 | Canon PowerShot A430 Digital Camera
Can;t get any pictures at night
hi there,
the camera needs enough light from the environment to produce good picture
in your case, have you used built in flash to support you while taking photos?
or if you don`t want to use flash, you need a tripod to ensure the camera position won`t shake
setting i usually use while taking a picture at night is ISO 100, f 22 and manual focus mode
Jan 10, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Panasonic Lumix DMC-FZ7 Digital Camera Logo
133 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
