Question about Logitech Laptop Speaker Z205 2 Speakers
I recently had to reformat my computer back to factory standards. I had the Logitech Laptop Speakers Z205 b4 this & they worked.After i reformatted now i only get volume out of my laptop built in speakers. Ive tried lookin for solutions online but nothing =(
  • Logitech Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 31, 2011
Testimonial: "thnx helped soooo much =)"
I need the schematic for Logitech Z205
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 20, 2012 | Logitech Laptop Speaker Z205
My Z205 worked when I first got it, but now it won't work. I have plugged it into another laptop and it's fine. I have tried all ports but no luck. The light comes on the speaker top so I know that...
If your using windows 7 go to the volume control in the taskbar right click it and select playback devices then make sure the speakers are set as default by clicking the speakers and then click set as default.
May 17, 2011 | Logitech Laptop Speaker Z205 2 Speakers
I have put the usb cord into the computer and turner the power on. The light is yellow on the side power knob but when I play a videoon my laptop the sound comes out of my computer not the speakers?
Right click the speaker in the lower left hand task bar select "open volume mixer" make sure the line out volume is not muted and turned up. Mute the PC speaker.
Hope this helps.
Zeppelinx12
Mar 08, 2011 | Logitech Laptop Speaker Z205 2 Speakers
I recently needed to reboot my computer back to factory setting due to what I figure was a virus now my speakers won't work. I have speakers labeled Logitech X-530 do I need a disk to add this as new...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 07, 2010 | Logitech X-530 Computer Speakers
Can i connect the logitech z 2300 speakers to my hp g 60 538ca laptop
Yes. Speakers have a standardized 3.5mm connector (the same as headphones). Your laptop also has a headphone port which will fit this plug and play sound out through the speakers.
Dec 29, 2009 | Logitech Audio Players & Recorders
Reformatted Computer. No Sound.
Looks like you haven't installed your audio drivers.
Dec 27, 2009 | Logitech X-240 Computer Speakers
I recently had to reformat my computer, and I don't have the software to reinstall the logitech program or whatever. Is there any way to get these working? the sound card is already installed in the...
Follow the procedure for speaker installation here. Verify it.
As this is a very basic output device, it uses the computer's Audio drivers to channel the sound from each speaker correctly. Make sure that your audio driver is installed and working. Other wise open another ticket and give us info on the sound card
Sep 02, 2009 | Logitech X-530 Computer Speakers
No sound
are u using vista? cause this is def a driver issue...could be the update Driver they released messed up things or the driver needs a updated from windows...it wouild help if u posted the driver version and Operating system u are using.
Mar 10, 2008 | Logitech X-540 Computer Speakers
Not all speakers working
Suggest that you download the latest Logitech drivers for your sound system.
Jun 10, 2007 | Logitech X-530 Computer Speakers
Logitech Laptop Speaker Z205 2 Speakers Logo
130 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
