Question about LG 19LD350 19Inch 720p 60Hz LCD HDTV 19 in TV
The screen of my LG tv model flatron M2762D-PC full HD 1080p . The problem is that the screen is constantly white with the words V3.05.0 Showing at top of screen, and cannot turn tv off/on by normal means what do you suggest ?
SOURCE: Power Only
On the LG TV remote, press either the "return" button or the "exit" button, then press power to turn it off and then power to turn it back on again.
Fixed!
(This happens when some other device remotes send a strange signal to the LG TV, putting it in a service mode).
Posted on Feb 19, 2010
budmrtn
  • 11361 Answers
SOURCE: My tv stopped showing picture but still apperears
If the whole screen is just white light, the the LCD controller (t-con) board may have gone out. Your TV can have more than one version of the boards inside.
You can get parts here: http://www.shopjimmy.com/catalogsearch/result/?q=LG+32LG30+
Posted on Dec 10, 2009
xptareq2000
  • 1447 Answers
SOURCE: I have an LG 42
When your TV (EHT) High voltage is not proper run or Power supply is not strongly create voltage.
Solve: If you repair it self,You check thoroughly.Some of components may be damage in power supply.
Check diode,capacitor or high voltage power transistor,any kinds of fuse.
Posted on Jan 07, 2010
SOURCE: when switching television[flatron m2262d]on shows
I had the same problem with my new LG. To fix this, press exit on the remote control then power off on the remote. Turn the TV back on and all should be well.
Posted on Apr 08, 2010
  • 14 Answers
SOURCE: LG flat screen TV speakers make a vibrating noise
How to stop LG tv speakers vibrating?
It's not as simple as it sounds is it because the cabinet is supposed to resonate by design. I have a workaround which works for my setluxhello.gif
If you think about it, the Cinema default EQ setting already increases Bass at default from flat.
Then if you consider SRS Trusurround also adds Bass too therefore You're already going to give the tiny tv speakers a good going over even at relatively low volumes.
Couple that with Freesat (which on my set is louder than all the other inputs) and then throw in BBC HD which has decent audio and it's probably no wonder it's crying at me with this vibration/buzzing.
So what I've done is tweaked the Cinema setting as follows:
SRS Trusurround : on (widens the soundstage nicely with these below on mine).
Auto volume: off
80hz = (0)
220hz = (-1)
470hz = (0)
1khz = -(1)
2.2khz= (1)
4.7khz(1)
12khz= (1)
I appreciate different room sizes/environments etc, but I honestly have it at 40 volume for the first time with no distortion. It's also giving me decent levels of bass and treble after trying in addition to BBC HD, Clubland tv, FIVE to give me the broadest samples of broadcast content/sound levels.
Posted on Jun 08, 2010
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
How do I replace SMART TV SCREEN MODEL NO : LG 55LM7600 55'' 3D 1080p Full HD LED LCD Smart TV
You cannot replace a screen that big. The manufacturers wont ship it to you. IT has to be done by an authorized service center.
Nov 21, 2014 | LG Televison & Video
Sound cutting out repeatedly,broken sentences , why
Does this happens with off air channels? did you try a dvd? or Blu ray
Sep 15, 2014 | RCA Lg 55lm8600 55" Led Lcd 3-d Flat...
Picture showing up small
hi try going into the menu on the tv select aspect raito select auto or 16.9 hope it helps
regards
shaun
Apr 04, 2014 | Panasonic 37" VIERA Full HD 1080p IPS LED...
My lg 27 M2762D have black screen with normal sound, and after restarting tv ,screen is normal for while and return to black
Could you solve it? I have a similar issue
http://www.fixya.com/support/t19795450-lg_27_m2762d_black_screen_after_random
Jan 27, 2012 | LG M2762D 27 LCD TV
How can I get a free manual for lg tv model m2762d
You can download the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Jul 29, 2011 | LG M2762D 27 LCD TV
I am trying to commect to my PS3 to an LG LCD tv which supports 1080P (Full HD). but as the game starts and when i check the TV it says 720P although the game and the TV both supports full HD. Do i need...
Hello there. There's a few possibilities. First, the obvious, do you have it set to 1080P in the Display Settings options? Secondly, are you using an HDMI cable? You need to be using HDMI to play games in full 1080P. I use the component cables (The red, green and blue ones) for my PS3 and when I'm on the XMB (that's the PS's desktop so to speak) it's displayed in 1080P but games will not play in 1080P, only 720P. Any old HDMI cable will do the trick, so don't get suckered by the price if you are going to pick up a cable!
Nov 12, 2010 | Sony Playstation 3 (PS3) Console
LG 19LD350 19Inch 720p 60Hz LCD HDTV 19 in TV Logo
591 people viewed this question
Computer Repairing
Computer Repairing
