Question about Bissell Vacuums
Were do i put water - Bissell Vacuums
  • 710 Answers
What make and model steamcleaner do you have?
Thanks,
Handie Andie
Posted on Mar 31, 2011
  • Handie Andie
    Handie Andie Mar 31, 2011
    Noticed you posted this under Bissell vacs.
    Most of the Bissell Steam Cleaners have a 2 part tank. To remove the tank, release the handle by pressing the foot lever. Then you can take the tank off. Release the catch in the back and lift the lid from the bottom tank. Note the lid catches at the front of the tank. Be sure to fit the catch securely when putting it back together.
    The tank has 2 parts. Inside the clear tank is a bladder. This is where your clean, hot water goes. Fill it through the round hole in the clear tank. You can empty the bladder by unscrewing the cap at the bottom of the tank.
    Your dirty water collects in the clear tank around the bladder. When you want to empty it, just dump it over and drain.
    Hope this helps. If it does, please place a vote for me. Thanks,
    Handie Andie
The dirty water tank will not fill up
Make sure it's putting the right amount of water down. Many machines brought in to my store for repairs are putting down just a small amount but people think its not extracting any when the real problem is not putting out enough water.
If that's not the case make sure there are no clogs or suction leaks anywhere which will greatly reduce water extraction.
Mar 15, 2017 | Vacuums
F7210-900 Steam Vac. will not put out water when switch is in wash position but it will put out water when the rinse position
There are two electrical solenoids inside the hood assembly. One opens to dispense rinse water, and the other dispenses the soap and water solution. It is likely that the soap and water solenoid has failed and will require replacement. A "work around" fix for this is to mix the soap solution in the clear water tank ( 5 oz. of shampoo per gallon of water ), and shampoo that way until the solenoid can be replaced.
Mar 15, 2011 | Hoover Vacuums
Hoover carpet cleaner does not **** water it blows
push the little square thingy down on the very front of the bottom bucket, then put the lid on before you put it on the machine, then let the force of putting it together push the front thingy up when you put the bottom bucket on the machine as one assembly..... it makes the seal right somehow..... ....my wife about pulled her hair out before we figured it out the hard way...... I may get a reward tonight......
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I don't have instructions for the Rainbow shampooer. I'm not sure how much water to put in, or whether I put water in both reservoirs. Does anyone know?
Water only goes into the cub in the handle. The dirty water gets put into the bowl on the canister part.
Nov 28, 2009 | Rainbow Vacuums
Don't know how much water to use in Scunci Steam Cleaner
The little cup that comes with it to fill it has a line on it and says "220ml MAX". I would not recommend putting anything but water into it!
Aug 08, 2009 | Scunci 52067 Handheld Steam Vacuum
Can't get it open
had same problem. Tried pouring boiling water over cap and it seemed to loosen some so I boiled more water and put the steamer top down in a bowl in the kitchen sink and pour the boiling water in and let it sit about 5 minutes. It came loose with some effort. The grooves are the opening are metal and they had started to corrode.Once open coat with wd40.
Jan 31, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
Do you put hot water in the tank
It would depend on whether you machine preheats the water or not,and what kind of machine,Bissell,GE,etc..If your machine doesn't heat the water,then I would use hot water.Do not boil water,tap is fine.
Dec 16, 2008 | Hoover SteamVac F5914-900 SpinScrub...
IWOULD TO KNOW IF STEAM CLEANER ARE HEATED WATER
yes, they heat water to over boiling point by putting it under pressure so you only get steam. it cleans with very little water.
Jul 27, 2008 | Vacuums
Water?
There are two tanks on that machine. The lower tank is the recovery for the dirty water and the upper tank is for the clean water solution. You mix the detergent with the clean water and away you go.
Feb 08, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Lost directions to the cleaner.
Hi , check the water level and refill it .
Jan 21, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
22 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
