Question about Juster AC-691 Computer Speakers
I have new speaker in my computer, but is not working what i have to do?
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 31, 2011
I have polk audio speakers that came with my old hp f50. I just purchased a new hp but can't get my speakers to work
The old speakers are not compatible. Your new computer is looking for an external power source for the speakers, the older polk speakers that came with Hp computers have none.
Sep 15, 2010 | Polk Audio AMR50 Computer Speakers
Dell speakers w/ HP computer - connection failure
Your HP computer may need the Drivers from the Dell Speakers to work properly.
Jun 19, 2010 | Dell A215 Computer Speakers
Last week my computer crashed down. We can't contact the technician who used to fix our computer. Now we found a new one who can reformat our computer but this time, he installed windows 7. Now, our...
Make sure the speakers are hooked up properly and also that the sound card drivers are installed, you can verify this by going into the device manager. The main speaker wire has to be hooked up to the output of the computer sound card.
If the sound card drivers are installed and the speakers are hooked up properly and your still not getting sound, try the speakers on another computer that you know has sound. If the speakers work then its a sound card driver issue on the original computer. If the speakers don't work on another computer then you know the speakers are bad.
Apr 15, 2010 | Logitech X-240 Computer Speakers
A215 speakers are not working....
Connect the speakers to a different computer.
If they still don't work, responsibly recycle them, and buy some new speakers. But, before you do, try the speakers from the different computer in your computer. If they don't work, then it's a problem with your computer, not with your speakers.
Apr 07, 2010 | Dell A215 Computer Speakers
Help! Only my right speaker works on my new speakers! Do I need a new sound card?
USB headphones and speakers tend to operate independently of the PC's sound card, but you can determine if your sound card is the problem by plugging the speakers into a different computer. If both speakers work on a different computer, then the problem does lie in the original computer. If so, try a different USB port, especially one that is directly on the computer, not in a usb hub.
If only one speaker works on a different computer, I would troubleshoot the cord that connects the left speaker to the right speaker. Perhaps it is damaged or not connected fully.
Hope that helps.
Oct 15, 2009 | HP USB Powered Speakers . Computer...
Use old speakers with new computer
The speakers are most likely running at an optmal rate. i may be able to help you more if you can tell me about the difference in the sound from the old destop to the new laptop.
Jan 20, 2009 | Altec Lansing ACS 495 Computer Speakers
Boston BA745 speakers
check where its plug in the back check your volume make sure its not on mute
Mar 03, 2008 | Boston Acoustics BA745 Computer Speakers
MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Oct 17, 2007 | Gateway FPD2275W LCD Monitor
No sound from speakers
Hi, Did you install the sound driver in your new computer? That is the first issue you should try. If the little speaker appearr at the lower right of the screen then the spearkers should be ready to go.
Oct 09, 2006 | Boston Acoustics BA735 Computer Speakers
Juster AC-691 Computer Speakers Logo
146 people viewed this question
Top Juster Audio Players & Recorders Experts
Martin Murray
Victorman
Victorman
Vladimir Frolov
Are you a Juster Audio Player and Recorder Expert? Answer questions, earn points and help others
