Question about Alpine CDA-9827 CD Player
MX does not work anymore
I've always had the MX turned on, everything sounds way better. Then the other day I notice the MX LED is not turned on and the stereo doesn't sound as good. Pressing teh MX button in the lower left hand corner of the display does not do anything. Any ideas???
  • Anonymous Aug 10, 2008
    I'm having the same issue. I changed a cd and then realized the MX wasn't on, and I can't turn it on, nor can I use the CENTER button to adjust the bass/treble. I unattached the face and reattached it several times and I shut the power off and turned it back on but it still doesn't work. Any suggestions would be appreciated!
  • bighitter Aug 12, 2008
    Thanks very much! It works now!!!
    Problem Solver:
Make sure the Deft control is set to OFF. Push the volume control until you see Deft on the screen and turn the knob until it says off on the screen.
Posted on Aug 12, 2008
    New Friend:
I had the same problems. I ended up getting a new car battery and some how it all works again.
Posted on Jan 15, 2010
I recently had the same problem and was able to solve it by resetting the unit. Remove faceplate and press little inset button that is close to the center.
Posted on Mar 11, 2009
Hello...same problem here.
Deft is OFF...but still can't activate MX, still can't controll bass or treble. Bass and trebble are at + - 0 ... and can't select anything else:(
a better solution?
Posted on Sep 29, 2008
SOURCE:
Logik LED TV making a constant tapping/clicking sound.
try turning off AND unplug for a couple minutes! USB may have pulled power down to start the switching noise. Try usb again and if it does it again then I wouldn't use that usb anymore.
Jan 17, 2014 | LG Televison & Video
Amp crackling noise
Sounds like you could have a blown amp/speaker or you've got a short in your speaker lead. Typically, when there's not enough resistance on a wire is when you start getting the crackling noises.
Aug 06, 2012 | Televison & Video
We have a Carrier 25HBA unit and we've noticed a frost build up on the outside compressor, my husband turned the unit off and cleaned everything outside and up in the attic. It worked. No frost...
Hello
Frost or ice on the bigger outside copper line is a indicatin of possible low freon.Hopfully that is all it is.
It is also a possibility the compressor is getting ready to break,bad valves.
You will need a tech to come out and charge the system with freon.
Check your filter is clean and new first.
Sep 15, 2011 | Heating & Cooling
I've been noticing a squeaking sound intermittently
Good day,i think the problem would be you hard disk sir,better to change a new one.tnx
Aug 16, 2011 | Seagate Barracuda 7200.10 ST3160815A -...
I have a JVC MX-GT80 there is a problem with it, it turns on just fine but does not give sound, plays cds and everything the only problem is no sound when this happened there was sound then i heard a pop...
It looks like you've either blown the speakers of the amplifier itself. What were you doing when you got the pop and the sound stopped? (Playing CD or from External Source and at what volume level?)
If there is no sound at all from the speakers, not even a crackle or buzz then it's more than likely you've blown the amplifier.
You could narrow the fault by trying these speakers on another unit or another set of speakers on this unit.
If you require further assistance then please ask.
May 10, 2011 | JVC MX-GT80 Shelf System
P4vp-mx no sound
kindly send the motherboard cd
Oct 06, 2008 | ASUS P4VP-MX Motherboard
ASUS P5VD2-MX SE sound driver
you can download the audio driver for your motherboard from some of the sites given below ...
http://www.nodevice.com/driver/P5VD2-MX/get34077.html
http://www.nodevice.com/driver/company/ASUS/Motherboard.html
http://www.driverstock.com/ASUS-P5VD2-MX-driver-download/6-9-10181/index.html
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Sep 02, 2008 | ASUS P5VD2-MX SE Motherboard
I want sownlod this software
My first reaction is why you want to use MX? Now that adobe have taken over Macromedia the new version of Dreamweaver is mark ably better by light years than MX. MX does not handle CSS half as well plus Adobe have linked all the apps such as Fireworks, Photoshop and flash to work with Dreamweaver. Adobe do not really support MX anymore so your best bet of getting MX is to search the P to P sites.
Sep 01, 2008 | Macromedia Dreamweaver MX 2004 for PC, Mac
ASUS P4VP-MX display problem
If I understand you right, your display is not coming on with your new hardware. Try the eliminaion process:
take out the new things. Install them one by one, and try booting each time you install one. If that passes, turn off and install the next one, until you isolate the one failing. Once you know it, installit properly or come back here for help.
Feb 18, 2008 | ASUS P4VP-MX Motherboard
Alpine CDA-9827 CD Player Logo
208 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
