Question about Maytag MSD2436GR Side by Side Refrigerator
Have Maytag MZD2766GEW Rev 10. The refrigerator side will not go lower than 45-50 degrees. I can feel the air flow from the freezer in the upper left hand side. When I removed the plastic cover at the top, the right side light bulb went out. After I poked and jingle things looking for the adaptive defrost assembly the light came back on for a minute and then went back out. Is this short part of the adaptive defrost assembly problem or a problem all it's own. The freezer side is fine - no ice on the coils or extra build up of frost. Help?
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
How to turn off lock on maytag refrigerator #mzd2766gew
To unlock the indoor ice and water dispenser push the button with the key image 3 times within 10 seconds and it should be unlocked...if later on ya want to lock it again also push that button 3 times within 10 seconds.
Sep 17, 2011 | Maytag MZD2766GES Side by Side...
Air Circulation
replace the upper thermostat
that must help
there will be three thermostat in total
Oct 09, 2008 | Whirlpool GC5THGXL Side by Side...
Hi..our maytag msd2351HE side by side is only making small amounts of ice..we are able to get water..Any suggestions?
I would suggest pulling the refrig out and removing the lower panel . On the right , there is a black box ( condensor ) . The fan pulls air thru the coils and dust , lint , etc , can block the air flow , causing the freezer to not get cold enough ( 5 degrees ) for the ice maker to work . Also check to make sure the fan there is working . If the fan is working and the coils are clean , try turning the freezer control slightly colder . If the fan is not working , replace the fan motor .
Aug 01, 2010 | Maytag MSD2351HE Side by Side Refrigerator
Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2456GEB fridge section warm
Please remember I am attempting to diagnose your appliance without being there and with very little information.
Sorry but if your freezer is 10 degrees, it is running warm. Freezer is designed to run between -10 and 0 degrees. Reset controls, place them in the middle of the scales. The controls can be confusing. The control that turns the unit on and off is your freezer thermostat and the other is the damper that controls the air flow from the freezer into the fresh food section. What I would think is wrong with your unit is one of two things.
  1. You have a defrost problem.
  2. Your inside fan is not running.
1. Look at the inside back panel of your freezer. If you have ice or frost built up on the panel, you most likely have a bad defrost heater.
2. Check to be sure you have air flow inside your fresh food section coming from your freezer. If not and your control is setting around mid-ways, you have a bad fan or your defrost heater is bad and ice is blocking the air flow.
Please rate solution
Sep 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Our Maytag MZD2766GEW is leaking from the freezer.
Remove the lower panel in the back of your freezer. and see if your defrost drain is clogged. Mine got clogged and froze up. Everytime it went through it's defrost cycle it leaked.
Apr 11, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezer is cold, but refrigerator is warm
Sounds like you have a defrost problem... is there a large build up if frost in the freezer section on the back wall??
Aug 20, 2008 | Maytag Refrigerators
Maytag side by side slowly getting warmer
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Maytag LRTC15A AH01A - not keeping insides cool - condensor fan working and clean - freezer fan working - cannot feel air flow to crisper (meat bin).
The flow ducts from the freezer to the lower part were frozen solid. Once fridge thawed and drained, all worked fine again. Flow duct very hard to get at.
May 13, 2008 | Maytag Refrigerators
Maytag MSD2436GR Side by Side Refrigerator Logo
153 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
