Need to buy a techwood 42" lvds connection load cable to fit tuner/media box but cant find them
3 Suggested Answers
mjjdesigns
  • 98 Answers
SOURCE: how to connect a sony monitor no tv tuner to a cable box
It's unlikely that you'll be able to use a computer monitor as a television.
Cable boxes have specific outputs, and computer monitors have specific inputs. They generally don't align with one another.
However, your monitor may have VGA inputs on it, and your cable box may have a VGA output (though unlikely).
If you can provide the model number of your cable box, and your monitor, I'll be able to help you more.
Posted on Mar 19, 2009
SOURCE: where can i buy a techwood twp4205 lvds cable for
www.wentek.com
Anniexia_0202@hotmail.com
Wentek Electronics is a professional manufacturing company specializing in cable assemblies and wire harnesses for:
- Flexible Flat Cable (FFC)
- LCD Monitor & Panel Connection
- Electronic / Electric Wire Harnesses
- Specialized Electronic Wire Connectors Solutions and specifically for your production & processing needs.
Posted on Apr 13, 2010
No tuner signal
Unplug the set and a box if used and then after a short wait plug both up to allow both to reboot.
If using the coax fitting on set you can with a box connect to rear inputs and bypass the problem= ie if the rear jacks work with a DVD etc.
May 06, 2012 | Olevia LT37HVS 37 in. LCD HDTV
How do i hook regular cable to Maxent MX-42EPM20 42 in. EDTV Plasma Television
Your Maxent MX-42EPM20 is not a TV (Television) it is a Plasma panel. The difference being your Panel does not a TV Tuner (no Coax jack or electronics relating to a tuner) Below is the spec sheet that shows this
http://reviews.cnet.com/flat-panel-tvs/maxent-mx-42epm20/4507-6482_7-32139310.html?tag=mncol;subnav
You can use a cable box or a cheap Digital TV receiver. You can buy them at walmart, You need one with A/V out puts such as Component. Here is a link to one. This will give you a tuner.
http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
Feb 18, 2012 | Maxent MX-42EPM20 42 in. Plasma EDTV
I cant plug the cable in the back there is no cable connector in the back of this tv i would like to know if there is a connector i can buy pdp monitor mix42hpm20
If you have a Maxent MX-42hpm20, it has the following connections: Component, S-Video, Composite, HDMI and VGA. There is no tuner included as it was sold as a monitor.
You need a set top tuner box (cable box or a OTA tuner - depending on your set up). One option may be to install a tuner on your computer and then connect the computer to the monitor. If you have digital cable, make sure the tuner handles Clear QAM. If OTA, then you can use a digital-to-analog converter set top box.
I hope this helps.
Feb 09, 2011 | Maxent Televison & Video
The Cable connection is broken, how do I replace it? the model is D52W26
Thats called the f-fitting or rf fitting. Its attached to the tuner on your set. You can either replace the whole tuner circuit or in most cases, replace the rf fitting with a new one as long as the tuner board was not damaged. We stock the fitting which are like 2 dollars a piece so I would think alot of tv shops would stock them. You could expect to pay around 125.00 or so depending on your location to have it done in your home. To do it yourself you will need to be handy with a soldering iron and be extremely careful in the tuner area not to damage surround coils..
A cheap or maybe free alternative is if your using a cable box, to just hook it up using video and audio patch cables which will bypass the TV tuner altogether. If you still have a vcr you could use it for tuning or buy a cheap converter box (as long as it has video and audio outputs) at most any local dept store.
Just run patch cable one yellow for video and the other 2 are red and white from the box to the tv. I think the boxes are around 25.00 or so
Oct 19, 2010 | RCA P52926 52" Rear Projection Television
Where can i buy a techwood twp4205 lvds cable for a plasma tv and media box and how much will it cost me?
www.wentek.com
Apr 05, 2010 | Televison & Video
Hi ive been offered a techwood twp4210 plasma tv and i have a couple of questions can you advise if this is hd ready also how old are they, have also been advised that on start up it shows green sparkles...
The unit was being manufactured in the early to mid 2000's but I believe is not out of production. It is NOT an HDV. Here are the specs for the TV.
Product details Manufacturer Techwood Built-in Sat-Tuner No Compact Flash Card No Digital Tuner without Digital Tuner DVD Player / Recorder No HDTV Norm No Loudspeakers without Loudspeakers Memory Stick No Multi Channel Receiver without Multi Channel Receiver Type No Multimedia Card No PCMCIA Interface No Common Interface Slot No DVB-C No DVB-S No Screen Format 16:9 Screen Size in cm 106 cm DVI Interface No Electronic Program Guide (EPG) No Screen Size in Inches 42 in Secure Digital Card No Energy Savings Trust Feature No HD Tuner No Smart Media Card No Type of Monitor Plasma Display, Plasma Horizontal Resolution in Pixel 852 PC Interface No Vertical Resolution in Pixel 480 Brightness in Candela/m² 650 HDMI Interface without HDMI Full HD without Full HD (1080p) DVB-T without Digital Tuner HD ready Not HD Ready LED Backlight without LED Backlight DLNA certified No Energy Saving Trust Feature No HDMI No HDTV No Internet Access NO WEB CONTENT ACCESS EAN 5017416142205, 5017416183666
Nov 19, 2009 | Televison & Video
Ted scaning elektronik tv service
I have a TWP4205[samsung display s42sd-yd05] end VMB 1110 tuner box for TWP4210[LG panel]Hou switched in service mode,for geometry settings...please!
Feb 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Connection for tv cable to hitachi 42" plasma Tv
there is no cable slot. the monitor is not a receiver. it has no tuner in it. it will need a signal from a tuner box. and that must be fed to the tv with an hdmi cable or a dvid cable for hd to work. see your manual for further information on cables. see your cable supplier for information on hd boxes available in your area. if you do not buy hd service, you will not get an hd signal. so you will see little difference from a non hd device. your dvd player may have hd capabilities, but will also need the same cable to deliver true hd signal.
the good news is that its fixable by using the right equipment.
good luck
mark
Dec 07, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
 Grubhead
Grubhead
