Question about Sony SDM-HS75/B 17" LCD Monitor
Sony monitor no input power - Sony SDM-HS75/B 17" LCD Monitor
Got struck by lightning via the modem which was destroyed. The port that accepts the ethernet cable stays on as soon as the computer is plugged in. Power comes on but no input to the monitor.
The modem might have been obviously destroyed but so is the rest of the computer. The connection that you are talking about is the NIC and it is showing signs that it was damaged by the surge also. That means all the delicate electronic parts in the computer are toast. Time for a new computer.
Aug 24, 2015 | Sony VAIO PCV-RS710GX PC Desktop
SONY SDM S81R
hello sir,,
since there is a problem with the monitor..u have to contact the sony vendor ,
u can contact them in 800-326-9551
n also 888-476-6972..
thank you
have a great day
Jul 06, 2008 | Sony SDM-HS75 17" LCD Monitor
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
I'm having problems with my Sony LCD monitor input
you make sure that your pc has 60 herz frequency on the verticle speed. the pc connection is at the back of your tv written pc with serial and a jack connection.
Jan 26, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
The screen will not come up but gave this message 'No input signal, go to power save
To isolate the problem, you need a friend with another computer since right now, we don't really know if the video section (or card) of the PC is at fault or the monitor.
You need to swap displays with someone so you can be certain what is actually not working.
The monitor is obviously capable of scanning inputs for a signal and not finding one.
Oct 26, 2008 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
SDM-HS73P Screen Flashes
This is a problem I have seen with a few LG monitors.
Your Inverter circuit is fine (that powers the lights to your screen so you can see the image on the LCD panel) but the monitor does not like having a video signal attached to it.
  1. Bad capacitors on the power board can upset the current going to the controller board. This board included the video input circuit and the power supply needs to be stable for this to operate.
  2. The controller IC that translates the video signal into what the LCD panel controller can understand is failing. Normally this fault occurs in the horizontal and vertical input of the IC. The fact you can see the other message on screen is due to it going through it's own internal and seperate section of the IC. In this case the only repair option is to replace the internal video board. Sony will not supply the parts directly to the public, but if you are really nice, they "may" tell you where to get one externally to Sony.
Hope that helps =)
Apr 16, 2008 | Sony SDM-HS73P 17" LCD Monitor
Green light "NO input signal go to power save" than white light at power
check the cable connecting from monitor to cpu is connected properly... try reconnecting it ... ur problem will be solved ...
Dec 03, 2007 | Sony SDM-HS73P 17" LCD Monitor
Sony SDM-HS75/B 17" LCD Monitor Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
