Question about Fisher and Paykel DG08 Electric Dryer
No heat--only cool air. - Fisher and Paykel DG08 Electric Dryer
  • Fisher and P... Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,./
Posted on Aug 13, 2011
Over heating and sputtering
kohler engine air cool they will over heat if fuel system lean carburetor clogged out of adjustment causing lean fuel mixture,air cool engine need plenty air to keep cool, make sure air filter clean and make sure cooling fins not clogged with debris make sure shrouds and blower housing are tight so air can circulate. air cooling engines kinda remind you of 1963 corvairs
Sep 09, 2012 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Furnace switches to auxiliary heat while in cool
It's likely a bad tstat. Turn the power off to your air handler. Remove red , green, yellow and orange wires inside the tstat and wire nut them together. Not sure if your reversing valve energizes in heating or cooling but, turn the power back on. If the unit is heating turn the power off and remove just the orange wire and turn power back on. Let this run and see if it you are ONLY getting cool air ALL the time. If so you have a bad stat. If still getting heat possibly you have a bad control board in the air handler. Good Luck!!
Apr 15, 2017 | Honeywell Heating & Cooling
Heat is not working. Just blowing cold air no matter the setting
is the "cold air" just room temperature air. put it on cooling and see if its colder than the air that is coming out of it when its on heating leave it on for a few mins make sure its cooling to.. it could be the reversing valve not pulling it onto heating if it can cool and not heat.
if its not cooling or heating it could be a few different problems. gas leak ,pcb boards ect.
Nov 09, 2010 | Amana PTH123B35AE Air Conditioner
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
Can somebody help,why is my Central AC blows
Most heat pumps have an auxillary heat. Many are electric auxillary heat with a heat strip in the air handler. A common malfunction is for the electric auxillary heat to operate when the heat pump is set on cool. To confirm this, locate the conductor that runs from the heat sequencer to the connection on the heat strip. You will see this on the top section of the air handler. Use the clamp on part of the amp meter over that wire. If the thermostat is set on cool and the heat strip is drawing amps, it means the heat is coming on while the heat pump is set on cool. There is usually one or two causes for this, either the sequencer is bad or there is low voltage wires usually behind the thermostat or in the air handler closet that are touching that shouldn't be touching.
If this is not the case, if its not a problem of where the heat is coming on with the air conditioner, it could be a case of the reversing valve malfunctioning. The way a heat pump works is it reverses the flow of the refridgerant. For instance, many heat pumps the reversing valve is activated in cool. That would mean that there is a low voltage circuit that activates the reversing valve when the heat pump is in cool. I'm not sure what model/brand your heat pump is, Goodman and Janitrol for instance, the heat pump reversing valve is activated in cool. In any case, if the reversing valve is not operating properly, when the air conditioning is set to cool it will actually be heating. Or you could set it to heat and it may actually be cooling instead of heating. Please check these two items first and if you have any further questions, please let me know. Especially if you know of any additional problems like the evaporater is icing up or if the air handler fan is not operating when it should.
Aug 31, 2009 | Heating & Cooling
Mitsubish mr Slim air contioner heat & cooling control panel
HOW TO WORK THE HEATING AND COOLING CONTROL PANEL
- PRESS THE SWITCH ONCE IT OPERATES "COOL"
- PRESS THE SWITCH AGAIN IT OPERATES "HEAT"
- PRESS THE SWITCH ONCE AGAIN IT STOPS.
Mar 05, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Fisher and Paykel DG08 Electric Dryer Logo
167 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
