Question about Samsung LN-S2651D 26 in. LCD Television
I have green "snow" through
    Genius:
  • 1,622 Answers
Remove your HDMI cable from the Cable box, replace it with Component Cables. Do not use HDMI with Cable.
Normally if everything is green using component cables it would be because the Red/Blue cables are not fully inserted somewhere either on the display or on the source device. But since when you turn it on, with no source connected at all and it is green it sounds like it is a defective TV.
Sony builds the best TVs in the world and here is another fine example of there quality work. This is a firmware problem that the Sony engineers should know about. Contact Sony and inform them of this problem. Maybe they already have a firmware update for your TV, if not, then they need to start work on this issue.
I have been racking my brains trying to fix my boyfriend's new Samsung TV which gets the dreaded "green screen." Being a former PC Tech I knew there had to be a work around.The issue seems to be an incompatibiity with the receiver and cable box which sees it as a repeater.
Today I actually found it by accident fooling around with the cable tv box settings. BTW it is a Motorola Cable box.
This went all the way to the Engineer who had no solution as you all have experienced.
Here is what I did...
Turned off the Cable Box and pressed the menu setting on the motorola remote till a white screen popped up.
Scroll down and disable the overide settings turn to off
Then scroll down to additional hdmi settings and hit enter
Change it from hdmi to dvi
Then exit and turn your cable box back on
Your screen will flicker a bit and then focus back to normal
Now try changing your channels from sd to hd it should be fixed.
It fixed his today and I hoped it helped you...
Posted on Mar 31, 2011
Samsung LN-S2651D LCD TV no picture
What happens when you turn the TV on? Is there a clicking noise or popping sound?
May 28, 2014 | Samsung LN-T4665F 46 in. LCD Television
My samsung LN-S2651D Comes on with perfect picture then after 5 minutes or so picture strarts to get white snow going down the screen
Tuner fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 24, 2014 | Samsung LN-S2651D 26 in. LCD Television
My Samsung LN-S2651D has sound but no picture
Check with Samsung, this model should still be under the 3 year warranty. You are having a problem with the backlight power supply. You can look on the back of the unit for the manuf. date, if its less than 3 years then go to www.samsung.com and process the online service request form.
I hope this helps,if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 20, 2010 | Samsung LN-S2651D 26 in. LCD Television
Can't get HD cable channels on Samsung TV
Have you check with the cable company to make sure they are broadcasting to you in HD ?
It takes more bandwith so some cable companies will charge extra for it so you will have to check.
Apr 17, 2010 | Samsung LN-S2651D 26 in. LCD Television
I plugged my 110 volt samsung 26 ln-s2651d tv into 240 volt ac. fuse? transformer? or garbage?
A lot of times it only pops the on board fuse, or if it has a transformer,  then it often simply "Blows" the Primary windings and not too much happens on the secondary, If it is a switchmode well then you probably will have to replace the entire thing.
Feb 01, 2010 | Samsung LN-S2651D 26 in. LCD Television
Horizontal Lines on a LN-S3241D
i'm sorry to say It's most likely broken. I think the LCD screen is going. Try calling up Samsung to see if they can fix it or repair it for cheap. Good Luck.
Aug 29, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Horizontal bar across to of screen after ps3 hookup
If the set is less than a year old and having a problem, then, it is covered under warranty. Does it happen when watching something in analog? Does it happen when watching something in High Definition? I think the diagnosis would be helped with a picture of the problem. For a servicer in your area contact: 1-800-Samsung.
Jun 23, 2007 | Samsung LN-S2651D 26 in. LCD Television
Samsung LN-S2651D 26 in. LCD Television Logo
50 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
