Question about Broderbund Computers & Internet
My Printmaster Platinum Version 18 software disk will not load the program disk into my windows xp computer, the window says it cannot find the install file. please help me. My e-mail is eclong@mediacombb.net
  • 2,427 Answers
The problem your facing is often caused by a damaged disc. I'll outline two solutions for you, the first involves the disc itself.
1.) insert the disc into the drive, close the autorun screen (setup screen)
2.) click start / my computer
3.) right click the disc drive with your disc in it and click open
4.) hold ctrl and press a or click edit select all
5.) hold ctrl and press c or click edit copy
6.) minimize the window
7.) right click on your desk top and create a new folder, (call it anything you want)
8.) double click on the folder to enter it
9.) hold ctrl and press v or click edit paste
10.) all the fies from the disc will be copied to this folder, if completed without any errors, simply double click on the setup / install icon to install the program.
Method 2 if the above fails.
1.) click on this like http://www.filestube.com/5c66b8541a429ddc03e9,g/PrintmasterPro.html
thats an iso image file of the print master 18 disc
2.) download the file
3.) burn it off to a dvd using ultra iso, a trial version will ,do download it here
http://www.ezbsystems.com/ultraiso/download.htm
download it, install it, double click on the printmaster disc, iso file, burn it to a cd
4.) install it as you would but USE THE SERIAL NUMBER AND KEY FROM THE ONE you PURCHASED!. piracy is illegal and fixya does not condone it, but seeing as you already brought it you already have a serial number and key so you dont have to worry. the disc image has a readme file for extra instructions.
Posted on Mar 31, 2011
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I HAVE A VISTA 'HP' PAVILION LAPTOP. I HAVE JUST PURCHASED YOUR 'PRINTMASTER' PLATINUM VERSION 18. I HAVE BEEN UNABLE TO LOAD IT ON MY COMPUTER. I HAVE MISPLACED THE DIRECTIONS THAT CAME WITH THE...
Check this link for the step by step way in installing this software but this is for 'PRINTMASTER' PLATINUM VERSION 17 but dont worry its just have the same procedure in installing the 'PRINTMASTER' PLATINUM VERSION 18, this is the link
http://support.broderbund.com/fix.asp?isid=44677&prog=1294820935&printer=1
Hope that helps.........
Aug 13, 2008 | Broderbund PrintMaster Platinum 16
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Feb 18, 2011 | Broderbund PrintMaster Platinum Version 18
Windows 7 Professional + compatibility with Broderbund Print Master Platinum Version 18
If a program cannot be run under Windows 7 because of compatibility issues, which is the case with Broderbund Print Master Platinum Version 18, you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Nov 20, 2010 | Broderbund PrintMaster Platinum Version 18
I installed window 7 into my laptop. My printmaster platinum 18 is now not working properly. What can I do to resolve this issue
Right click on the program shortcut click on properties from the menu and click on the compatibility tab , check "Run this program in compatibility mode of windows xx" and select the version of windows in which the program used to run. Apply the settings and open the program again. If the program still doesnt work try to reinstall or get an updated version for windows 7 maybe Print Master 2010.
Sep 12, 2010 | Broderbund PrintMaster Platinum Version 18
I have chnged my computer system form XP to Window, now I cannot install PrintMaster Platinum Version 17? Is there any way that I can istall this program disc?
Thank you for your question.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
All the best with your install.
Kind regards
Jul 20, 2010 | Broderbund PrintMaster Platinum Version 18
Windows vista will not bring up my Printmaster 18
Right click on the icon which launches the software, Properties, Compatibility tab, and change it to XP.
Aug 22, 2009 | Broderbund PrintMaster Platinum Version 18
I have purchased PrintMaster Gold version 18 three times and returned two of them. My computer is operating on Windows XP service pack 2. My computer does not seem to find any data on the install disk....
You might have a problem with your CD/DVD drive. Try inserting the CD in another computer. If the files are shown, replace your CD/DVD drive or just add another CD drive to an empty bay of your computer.
Jul 31, 2009 | Broderbund PrintMaster Platinum Version 18
Installing a new verison of Printmaster
No,pm18 wil over come pm10 in ur comp OR uninstall the Pm10
Feb 03, 2009 | Broderbund PrintMaster Platinum Version 18
Cannot install PrintMaster platinum version 18 on 2of 3 computers
on your desktop go to run and look for your software then run it
Jan 06, 2009 | Broderbund PrintMaster Platinum Version 18
Computers & Internet Logo
170 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
