Question about IBM ThinkPad T21 Notebook
My ibm thinkpad from the year 2000 wont turn on. i have connected the adapter and put the battery. i press the button to turn it on but the laptop wont turn on
    Problem Solver:
  • 17 Answers
1st thing you need to do is to make sure the adapter is working.
check to see if any LED indicator lights up when you connect the charger.
if none of the indicators light up with the charger plugged in, you may need to consider replacing your charger/adapter.
however if the indicator come on, then it is most probably a problem with your power/on switch (at the least) or a problem with your motherboard (at the most)
Posted on Mar 31, 2011
Will not turn on
Remove the battery and ac adapter. Press power button for 10 seconds then connect the ac adapter. Turn on the system. If this didn't work. You need to go to a service center to test your motherboard.
Jul 20, 2010 | IBM ThinkPad T21 Notebook
Dead laptop
1.Turn computer off
2. Remove the battery, charger and all accesories connected.
3. Press power button for 1 minute
4. Connect the power adapter only.
5. Turn on the computer.
If not turning on and not even boot to lenovo screen then posible issue with the hardware. call the manufacturer if you are still within warranty they can fix that for free.
Mar 28, 2010 | IBM ThinkPad T30 2366 Notebook
IBM R40 laptop will not start.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 22, 2010 | IBM ThinkPad R40 2722 Notebook
Nothing on screen when I turn Thinkpad on
Mar 06, 2010 | IBM Lenovo ThinkPad R60 Notebook
Ibm thinkpad laptop
first, remove any external device as well as the ac adapter and the battery. while the ac adapter and battery is out, press and hold the power button for about 15seconds. then reconnect any power source and turn on the system. if it still doesnt turn on, remove memory, expansion cards, hard drive and optical drive then turn on the system. if it's still not turning on, the motherboard is faulty. but if it do turned on, reconnect the removed components one by one so you will determine which component is causing the issue. hope it'll help. good day. =)
Jan 07, 2010 | IBM ThinkPad A21m 2628 Notebook
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.Some time it boot up and run but then it won't do it nextime after it been power off. Battery for BIOS is good, Main...
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | IBM ThinkPad T30 2366 Notebook
My laptop wont finish shutting down. and it wont turn off manually.
press the power button unitl laptop switches off,if doesn't,unplug ac/dc connection and take battery of.if the laptop takes time to shutdown,your profile could be too large.
Jun 28, 2009 | IBM ThinkPad T20 2647 Notebook
I have a IBM 600x recently installed windows xp sucessfully and today it wont boot up at all it wont acept a charge using the ac adapter apears to have power/the adapter light lights up when not plugged...
Try taking the battery out and just use the AC adaptor.
Does the PC "come on" when you press the power button?
Does it show the animation bar at the bottom of the screen when XP first starts?
Apr 25, 2009 | IBM ThinkPad® 600X (2645-9ZU) PC Notebook
My IBM Thinkpad T40 2723 will not boot up
The first thing to try is to unplug the power adapter from the computer then remove the battery. Then press down the power on button for a second or two. Put the battery back in and reconnect the power adapter and see if it boots.
Mar 26, 2009 | IBM ThinkPad T40 2373 Notebook
IBM Thinkpad laptop wont start up
hi dear
Hi RD, Ouch! Have you tried taking the battery out to see if it will run on AC power when the battery is not installed? Sometimes a bad battery can kill the system.
Do you have a meter that you can measure the output of the AC adapter with to see if it is correct? If not, any chance you could swap adapters with someone for a while to see if theirs works on your computer and vice versa? A local shop may also be able to test your adapter to see if it's working.
oke
regards, cropp
Mar 27, 2008 | IBM ThinkPad T41 Notebook
IBM ThinkPad T21 Notebook Logo
110 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
