Question about Vtech Communications VT 4121 4 Phone (VT-4121)
My VTech VT 4121 has performed well for several years, except that occasionally the line would not open right away when I lifted the receiver or pushed the line buttons. I tried re-initializing but it didn't help. Today I noticed that the LCD screen was blank and the buttons were dead. I re-initialized again and it locked up at "Check date and calendar". I let it rest for a while and tried again, and now all I get is black boxes. Is something on the board kaput, or might there be a solution? I am technically quite handy and could repair it if pointed in the right direction.
SOURCE: Problems with C110 & A110 Vtech Mirage Dect Home phones
Have strangely got the same problem - about the same time you posted this, but intermitently. I have isolated that the problem is in fact the handset itself, not the base unit. I eliminated a problem with the base unit by a) registering a different DECT phone to it. - The base still works fine. b) Leaving the handset switched off for an hour or so (press and hold the "OK" botton to switch off / on); then whislt it was working, registering the handset to a different base (Base 2). And guess what, after 30 mins the "BASE 2" message started flashing on the faulty handset.
So, if you already have an A110 extension handset, make sure it's also registered to base 1 and maybe try to get just the handset repaired via VTECH. (or just buy a new handset if they are available).
Posted on Jun 26, 2008
  • 5 Answers
SOURCE: Vtech 2656 cordless phone battery not charging
These phones seem to have this problem, I'm not sure a new battery will fix it. I have found a wierd fix that works for me, but I have no clue why.
1-take the battery out,
2-leave it out about 30 seconds,
3-then put it back in but leave the cover off,
4-place it back in the cradle however you can with the battery hanging out (I wrap it around),
Now it will charge much more thoroughly for some reason???
Posted on Apr 16, 2009
SOURCE: Vtech VT 2656 2.4GHz
Was looking for this for awhile as well, if you held onto them like I did the wait paid off, they must have put this up since I last looked.
http://www.vtechphones.com/vtechui/support/faq_problem.cfm?model_id=F0D43FC0-19FE-4ABD-BC22-C1306B1EC90A&type=problem&parent_id=133
Posted on Jan 02, 2010
  • 102366 Answers
SOURCE: User's Manual 6772 Have been away
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=21705
Posted on Aug 02, 2010
emissionwiz
  • 78267 Answers
SOURCE: my vtech phones show NO LINE; MY OTHER PHONE WORKS
More than likely the phones base station (transmitter) is defective, this is a common failure on Vtech cordless phones, i have owned two and both failed the for the same reason. I also see this problem posted often for Vtech phones.
Posted on Dec 02, 2011
All of my handsets say phone in use and i cant get them to hang up
Please check the line input at the base, if the cord is damaged or the line has no dial tone, you'll receive that message in all headsets, you could test by connecting any basic wired phone to the same cord, if there's dial tone maybe you have a defective handsets base.
Feb 21, 2011 | Vtech Digital Cordless Telephone VT-2568
Phone base set 'in use' led flashes when plugged into the jack
As is usually the case, a very simple solution in the end. Always check every thing even if the info supplied is from a qualified person. The phone came with the wall jack to base cord but it wasn't the origonal one so the phone thought the line was busy because it wasn't receiving any voltage supply as the plug into the base set had transposed 1 with 2 & 3 with 4. Damn I hate it when its that easy. I was talking to another mate about it and he said he had a similar fault to mine & he thought the cord was the issue & he was correct.
Thanks for your time
Brent.
Nov 23, 2008 | Vtech VT 2651 2.4GHz Expandable Cordless...
60 Hz hum on recorded messages
The described problem is not a settings problem and is probably a internal malfunction. Try consulting Vtechs support center.
Jan 09, 2006 | Vtech VT 9152 Cordless Phone (VT-9152)
Vtech Communications VT 4121 4 Phone (VT-4121) Logo
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
