Question about Kenmore Washing Machines
I have a kenmore front load washer (417.29052991). The faster spin part of the spin cycle doesn't spin. The pre and post slow spin to fluff the clothes works fine. What could be the problem?
  • 641 Answers
SOURCE: Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Posted on Jun 29, 2006
  • 1294 Answers
SOURCE: kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Posted on Jan 21, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore Washing Machine Model 23912-100
you may have spin tube grease leaking into the clutch causing the clutch to slip during spin and then not getting up to full spin speed. it is common and will require you to replace the clutch. its not an easy job for the do it yourselfer as you need to remove the transmission to get to the clutch.
Posted on Dec 28, 2008
SOURCE: clothes dryer motor overheating
Have you repalced the thermostat?
Posted on Jan 12, 2009
  • 113 Answers
SOURCE: Washing Machine doesn't spin fast enough
Most likely needs a new clutch. www.washermd.com dave
Posted on Jan 14, 2009
During the spin cycle it spins correctly until the last 2-3 minutes and then it just fluffs clothes
Some machines used a variable speed slow down process to avoid clothing damage, this removes the items from the outside of the drum where if the clothing was left for a length of time after the cycle has finished it could damage the fibres, this way the clothing is also easier to remove from the machine and promotes airflow over the items
Jun 14, 2016 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
I have a kenmore 3 speed washer mod # 20722990. The problem is when in the spin cycle the water will not drain completly and the spin is very slow. The agitation in the wash cycle is good. Thank you for...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
p'';
Mar 05, 2011 | Kenmore Washing Machines
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
44 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
